- Nov 14, 2006
Hi to all,
For some time now I started working on a 8 bar twisted damascus blade, for a bowie I have in mind. I took a lot of pictures of the process and I will start showing them.
Note: when I decided to take pictures of the process I already had the base damascus already made, so I took some pictures of other damascus proyects, as the procedure is the same.
Cuting and grinding the layers. I use 15n20 and 5160 for almost all of my damascus now...
Ready to arc welding
Handle
And kersosene. I have seen in american WIPs that you have translucent kerosene, here kersonse is red.
And forge
And welding with press
Grinding the arc weld stitches
Now its clean and we can continue
(here you can see a W arrangement, not the billet I actually used, but wanted to show my whole process)
Ok, after that re stack and welding again.
Now we start with the real billet.
It has a diferent arrangement than the merovingian, but a similar principle. The merovingian has a sandwich of many layers-3 thick layers-many layers. This one, has many layers-3thick layers-many layers-3 thick layers-many layers.
Now we start drawing it out
For me power hammer is faster
Here is the first jig I use in my turkish damascus
Nothing fancy, but really helps in achieving even bars.
Second jig, this one is really good for squaring up any diamond shape.
Looking good
That is one bar, the original billet was cut in half because the bar would be very long, like forging a wire.
I didn't cut the billet in equal halves or it wasn't really even at the time so it yield one longer bar than the other one, so I seize that mistake later on, you'll see.
The twisting machine
Handle
And forge
Looking good
