- Jan 5, 2014
well i successfully produced my first piece of scrap metal today. i was thoroughly frustrated when i had to deem it as ruined, but i suppose its part of the process and was bound to happen eventually. So previously i was working with a crappy 100 grit sanding belt that took what seemed like eons to create a bevel, but it was hard to mess up. Today i got a shipment of quality new belts, so i slapped on the fresh 60 grit and went to work. what a difference! using a new sharp belt really puts a bevel on fast. so i ground one side exactly the way i wanted, and was very happy with it, good plunge lines and at the bevel height that i wanted, clean and straight. then i flip to the other side and just completely jacked it up..... first i accidentally dug way to deep on the bevel closest to the plunge line, so i had to make it into a full flat grind (pissed), and then i had to flip it over to make the other side a full flat. well what i didn't pay attention to was how thin my edge was getting and sure enough i burnt the tip off, bad.
but anyhow, i have been doin all my grinds free handed, i am pretty good at doing the left side of the blade, but when i flip it to the other side i cant seem to consistently get a symmetrically ground bevel....
So my question to y'all is, should i continue to practice grinding bevels free handed, and just bite the bullet if i mess up a blank? or should i switch to a jig? and which method is more "professional" (currently i only do flat grinds and scandi's)
sorry for the long post
