Twenty 3V Field Knives, micarta, G10, colors, "Delta 3V" SOLD
Nathan the Machinist
KnifeMaker / Machinist / Evil Genius
Moderator
Feedback: +143 / =0 / -0
The Field Knife was designed as a collaboration with Lorien Arnold. It is a well made, no frills, high performance utility knife. The steel is Crucible CPM 3V at HRC 61-62 with the fully optimized heat treat with very good edge retention and edge stability. You'll be surprised how sharp this gets and how well it holds an edge. If you have never used 3V this hard and thin, it is gonna blow your mind.
This steel with this heat treat will support a fine edge, so this was taken down to .015" before sharpening (though I'm leaving some additional meat in the tip now) and it was sharpened 18 degrees per side. This is relatively acute and it cuts well, but is very durable. They're also lightly hand ground after machining to give it a slight convex grind.
Some might consider this a tactical knife but the point is not reinforced and it is not shaped or balanced as a weapon. It's reasonably thin behind the edge. It is a hard working cutting tool, a big skinning knife and woods knife. There is a pry/scrape in the tang.
The handle is ergonomically designed for a standard forward, reverse, saber and pinch grips for an average to relatively large hand. The tang is internally skeletonized. The scales are 3D sculpted CNC machined. The blade is made of 3/16” 3V with a heat treat that has been optimized to maximize edge stability in rough use. Despite being relatively thin it is durable. You can baton with it. You might damage the fine edge if you set your mind to it, but the knife itself is practically unbreakable.
A side effect of this heat treat is a higher percentage of free chromium, so although it is not stainless, it is nearly so.
Specs:
3V, tested 62 HRC, .188” thick at ricasso
This 3V is a fully optimized 3V for this hardness and application
Total length 9.75”
Blade length 4.625”
Weight 8.0 oz
Grippy 3D machined scales in micarta or G10
Black oxide treated 18-8 stainless steel fasteners
Jared Corry sheaths are custom made for these knives and are well designed and well made. They can be worn vertical or horizontal and can be configured for left hand or right hand carry. A black sheath shown in the pictures but the sheaths in this sale are not black, they are tan or olive green, choose the color you want.
Tell me what scale option you choose and I'll build it. There are Twenty knives available in this sale. The knives in the picture are not the knives you will receive. They need scales and sharpened so they will not ship until end of next week.
1.jpg~original
2.jpg~original
3.jpg~original
4.jpg~original
5.jpg~original
6.jpg~original
7.jpg~original
8.jpg~original
9.jpg~original
10.jpg~original
11.jpg~original
12.jpg~original
13.jpg~original
The sheath color options are tan or green:
1.jpg~original
Rather than just take my word for it I made a video:
[video=youtube;1w1_WX_fNN8]https://www.youtube.com/watch?v=1w1_WX_fNN8[/video]
These are all “field grade”, “as machined” and stonewashed with tool and grind marks.
$235 in micarta, black or brown
$245 in solid color G10, black, OD green, Forest green
$255 in multi color G10, OD green / black
We have a few in some of the old multi color G10 available
We're winding down this pattern soon and don't plan to run scales for it again. We're running pretty low on some of the scales colors, so they're available "first come first serve" if there is a shortage.
Includes a good kydex sheath. You have a choice of olive drab green or tan.
Shipping in the USA is $10.
These knives are unusual because they are machined. I do this in my shop on industrial CNC machine tools. A WIP thread documenting my technique can be found here: http://www.bladeforums.com/forums/showthread.php/1048443
I take paypal, cash, check or MO.
We'll have 20 3" "Delta" 3V EDC knives here in two weeks!
Thanks for looking,
Nathan
1 x CPK-FK please in unbuffed natural micarta and no sheath. My PayPal email and shipping address are the same as on file. Thank you :)
I would like a field knife please. OD green/black G10 with a tan sheath.
I will take one in tan or black micarta, or terotuff if that is what is left.
innnnnn
I'll take one, in black micarta, please.
Considering the options, I'll go with the green sheath.
Thanks,
I'll take one, thanks
Od green/black g10 with a green sheath please.
Thank you
testing. just wanted to see where I would score. I have my field knife but one is enough.
Thanks Nathan and Jo.
I will take one in black Micarta please. I would like a tan sheath.
Unsure of your PayPal and order process from here. I PM'd you (you're probably flooded).
I want one
Solid OD green g-10
Tan Kydex sheath
mail sent
Jo, I'll take one. First choice is solid OD Green scales/OD green sheath.
Second choice is solid black G10 scales/OD green sheath.
Thanks!
Bob,
