If you would like to purchase a knife please specify which one buy its type and number. Payments can be made with paypal at pandrewbures@yahoo.com or you can pay by postal money order. If you would like to use a credit card, I can send you an invoice with paypal and you can use any card you want. If you would like shipping outside the U.S. please PM for a quote.
#1. Kwaiken Price: soldShipped in the U.S.
It is made from AEB-L stainless steel. It has been plate quenched then cryo quenched. After that it was tempered to be in the hardness range of 59-60RC. The blade is ground with a right side chisel grind and a left side back bevel. The handle is wrapped with dark red paracord that was soaked in resin, the menuki is made from titanium. It has nonslip grip tape under the wrap. It comes with a leather cross draw sheath.
7 1/4in long X 1/8in thick X 1in wide. Handle 3 1/2in long
#2. Kwaiken Price: SOLD Shipped in the U.S.
It is made from AEB-L stainless steel. It has been plate quenched then cryo quenched. After that it was tempered to be in the hardness range of 59-60RC. The blade is ground with a right side chisel grind and a left side back bevel. The handle is wrapped with black paracord that was soaked in resin. It has nonslip grip tape under the wrap. It comes with a kydex sheath that is set up for a small Tec-Loc. The retention on the sheath is on the wrap not the blade itself. So there is some blade play inside the sheath, this is to keep the kydex from marring the blade so bad. The knife has to be pulled on for it to come out.
7in long X 7/8in wide X 1/8in thick. Handle 3 7/8in long.
Kiridashi Price: $50.00 Shipped in the U.S.
It is made from AEB-L stainless steel. It has been plate quenched then cryo quenched. After that it was tempered to be in the hardness range of 59-60RC. The blade is ground with a right side chisel grind. The handle is wrapped with black paracord that was soaked in resin. It has nonslip grip tape under the wrap. It comes with a kydex sheath that is set up for a small Tec-Loc. The retention on the sheath is on the wrap not the blade itself. So there is some blade play inside the sheath, this is to keep the kydex from marring the blade so bad. The knife has to be pulled on for it to come out.
5 3/4in long X 1in wide X 1/8in thick. Cutting Edge: 2 1/2in long.
