- Apr 28, 2007
Pit,
Hope all is well brother. I would go with pjcb and birch bark.
PJCB and a small piece of fatwood. :thumbup:
I knew PJCB's would be popular......I'm suprised some others have not been mentioned though !
..... can you ignite C4 with a ferro rod?
In that same thread, MuzzleUp gave his recipe for his "kisses of fire" made with CB, beeswax, and PJ wrapped up (twisted like Hershey Kisses) in waxed paper, which introduces a little more wax into the mix....the first beeswax (egg carton firestarter) I lit didn't want to go out, at 20 minutes it still had a 1/2" flame. It finally died at 21.5 minutes. The next one lasted fifteen minutes, then 10.75 minutes and the last one was 12 minutes. All the candle (paraffin wax) ones had much shorter burn times. The first was 6.5, then 8.16, and finally 9.5 minutes.
This round of burning showed a significant difference in how the two fuels burned. In all cases the beeswax versions significantly outlasted the regular candle wax ones. Both produced enough head to melt the ice off of 2x4 sized lumber and catch it on fire. Easily catching small pieces of wet wood, even green wood.
First tinder: Firestraws with beeswax instead of PJ. The wax burns longer than PJ and paraffin. (see quote below)
Second tinder: Inner tube rubber scavanged from Ranger Band stash. Rubber burns tenaciously and for a very long time.
Process: Get the firestraw burning with a spark from ferro rod, then feed the rubber into the flame to ignite it.
Here are results from a test that was done in 2002 by Cliff Stamp.
Another tinder alternative is calcium carbide, which produces acetylene gas when mixed with water. This was used in miner's lamps and can still be gotten online, although the Hazmat handling fees makes it expensive. Controlling the rate of water feed into the reaction vessel determines the rate of acetylene gas production. However, wilderness control of the reaction in jury-rigged equipment might not be exact enough to be practical.
Petro jelly cotton balls and a small piece of pitchwood, maybe preshaved and packed in around the PJ cotton ball.
