- Dec 14, 2019
How much heat we talking? How do *you* usually heat it up?My thoughts exactly, heat up the screw before you try to unscrew it. That should sotfen any loctite in there and keep your torx drivers in good shape.
Hey have one question: do you let the tread locker dry before reassembly or put a drop on and assemble right away?Crikeyyy [How much heat we talking? How do *you* usually heat it up?]
See post #12
When reassembling, you don't actually need threadlocker. However, rather than overtorquening out of fear to loose a screw, you may use the weakest Loctite (purple, N° 222). Clean the threads and put only a very small drop on them.
Depends on the brand of threadlocker Martin, your best bet is to follow the directions on the bottleHey have one question: do you let the tread locker dry before reassembly or put a drop on and assemble right away?
Depends on the brand of threadlocker Martin, your best bet is to follow the directions on the bottleSome allow pre-application, some need to be assembled right away and then left alone for 24 hours...all should have the surfaces thoroughly degreased before use though.
Sorry Martin, I'll read them for you if that helpsI guess I’m a true guy, who doesn’t read directions until to late or are too small to read. Guess I have to learn new ways.![]()
As many others have said Wiha works,![]()
I use one of those turbo flame lighters with a very narrow flame. Takes about 10 seconds of heat on the screw .How much heat we talking? How do *you* usually heat it up?
God I am losing my mind more and more everyday. Don't know how I missed that one postCrikeyyy [How much heat we talking? How do *you* usually heat it up?]
See post #12
