muskrat man
BANNED
- Aug 14, 2005
Ok, Here we go.
First step was to clean up the edge and remove some of the rust and corrosion from the blade.
Before:
After:
Look at what a backspring, they used to build'em right, didn't they?
now it is time to strighten out that bent liner.
Before:
After:
Put her back together:
Now the blades had some side to side play, when I put it back together I had some excess pin sticking out of the bolster, I gave it a few good raps with a ball peen to spread the pin and correct the side to side play.
The bolsters were pitted, dinged, and marred, so I filed and sanded them smooth.
Before:
After:
Then I peen over the rocker pin:
Not pictured, I clean the liners with 220 grit sandpaper, after removing the other handle and get ready to add new scales.
New handle blanks, elk stag:
Before:
After:
Before:
After:
Before:
After:
