So the whole idea for laminates is to have a good edge steel do the edge thing, and something "tough" (whether that means very plastic or actually tough) on the sides. What would you make as an "ideal" laminate to make a blade that has an amazing edge but tough overall?
The complications are:
Not every steel is going to forge at overlapping temperature ranges, or be able to be reasonably heat treated together. (Not much point in using some super steel for the sides if you can't at least austenize it to get those properties.)
The other "big" issue is carbon migration. If your outer layers have .6% carbon and your core is S110V with 2.8 carbon, but the time you get done the core is going to down below 1% and your sides are going to be hypereutectic. I've heard it suggested that a layer of nickel may stop migration, but at a strength cost. I don't know if there is another type of construction that can limit the diffusion (like an edge to edge rather than sandwich), but I doubt it. So using steels with similar carbon levels to limit the amount of migration might make the most sense.
So while S90V with S7 might be attractive, 3V with with S7 might be a good combination if you heat treat at the higher temp for wear resistance.
Not trying to reinvent the wheel - monosteels work great, as do more normal laminates. Just thought the topic would be interesting. Thanks.
