- May 13, 2019
A good magnification device preferably with an inbuilt light.what test can you do if you don't have a BESS tester?
I see Mr. ronbowusmc gave us a nice bone to chew.
The burr could be aligned with the apex so you won't feel it with your fingers. It will shave and slice tomato but as soon as you hit a harder material (like pine cutting board) the burr will fold and there goes the sharpness.
In this case the BESS tester would show there is a burr. The burr will fold over when hitting the wire.
But; what test can you do if you don't have a BESS tester? Apparently ''I can't feel the burr with my fingers'' test is not very reliable. How about paper test? This aligned burr can also cut paper if it can shave and cut tomato.
I do have 60x loupe with inbuilt light and sometimes I can't see the burr but I know it's there. If I drag the edge a few times across pine or spruce wood the knife won't cut news print across the grains smoothly.A good magnification device preferably with an inbuilt light.
It has helped me.I recall reading an interview with Phil Hartsfield about how he finished his sharpening to eliminate the bur. He said he would cut thick cardboard with every knife after sharpening to ensure there was no bur at the apex. Not sure how accurate or true it is, but his knives were definitely sharp!
I know exactly what you mean, when you have properly deburred, the knife will slice paper with nearly a silent swoosh sound. You know straight away, but if there is even the slightest burr still there, it just doesn't sound the same. The burr, the bane of sharpeners.I do have 60x loupe with inbuilt light and sometimes I can't see the burr but I know it's there. If I drag the edge a few times across pine or spruce wood the knife won't cut news print across the grains smoothly.
But if I deburr the edge properly I can shave and whittle oak wood and the knife will cut any paper in any direction after that.
Well, sort of. I sharpened my PF719 to have a nice smooth edge and indeed it goes through the paper like there is no paper.I know exactly what you mean, when you have properly deburred, the knife will slice paper with nearly a silent swoosh sound.
Was he cutting the cardboard to remove the burr?
Yes, that was how I read the article.Was he cutting the cardboard to remove the burr?
Yes and. If you have a pretty good idea of how your steel and sharpening method are going to interact, then that is not that big of a deal. I'm pretty sure I can't get a burr aligned like that free hand, and even if I could, I'd be noticing something on the finishing strop passes, in fact, I usually do notice the asymmetry at that point, but it gets corrected by the paste.I see Mr. ronbowusmc gave us a nice bone to chew.
I see. I somehow missed you are using strop at the end of sharpening.Yes and. If you have a pretty good idea of how your steel and sharpening method are going to interact, then that is not that big of a deal. I'm pretty sure I can't get a burr aligned like that free hand, and even if I could, I'd be noticing something on the finishing strop passes, in fact, I usually do notice the asymmetry at that point, but it gets corrected by the paste.
Interesting approach.I think so, it's pretty abrasive. And the slicing motion might wear down burrs and catch points.
I have somehow reversed approach. I strop at the end of the sharpening and then I cut some wood. If there is a burr it will fold or partially tear off. Then I do a paper test cross grains. If the knife stutters or tear the paper I strop some more till the edge is burr free.
I finish off every knife on a large Gossman steel.
I tried micro bevel a few times. I did it a few times on the same diamond plate I was sharpening and a few times I did it on finer diamond plate. It technically works but somehow I don't like a micro bevel concept.
I also tried all sorts of loaded strops - cork, wood, cardboard and jeans. They work but I didn't like the feedback. Loaded leather strop gives me the best feeling.
I've seen the results of steeling on ribbed and smooth steel on SEM images but I never tried it. I somehow don't like the idea of dragging the edge against metal.
