- Jul 13, 2007
Right on guys, this is really helpful! Thanks for the pics prime77.
That provides some nice perspective. I think i'm gonna have to go Umnum...first...Any more thoughts or pics.
I also tried assembling without loc-tite. Seemed ok at first, but it did eventually loosen up on me and I am not keen on having the pivot on my Umnumzaan loose as it has come open in my pocket on two occasions.
I highly recommend that you use loc-tite as instructed by the manufacturer. I have NEVER had one of my Sebenzas come open unintentionally.
How were you carrying your knife when that happened ? Also the pivot tension should do little to change the detent strength, which is what holds the blade closed.
Good question. I used to carry clipped to my front right pocket. One day I lost my Micarta Inlay Sebenza 21 when apparently it slipped off my pocket and I did not realize it. I replaced that one with another Micarta version but with an Insingo blade. That also has slipped from my pocket but luckily I heard it hit the tile floor. Suffice it to say that, regardless of how many people rave about them, I do not trust these clips at all. I now deep pocket carry ALL of my Chris Reeve knives and no, there is absolutely nothing physically wrong with any of my clips. Buyer beware as far as I am concerned.
So...while deep pocket carrying my Umnumzaan I reached down one day and got a nice slice in my hand because it had come open in my pocket a cut right through an otherwise fine pair of jeans. Sharp Knife! This never happens with my Sebenzas. I figured it must have been due to the glass breaker hitting the bottom of the pocket (or something in the pocket) and causing the blade to pop open a bit. So, I switched to a tip down carry. A couple of weeks later I sat on my couch and heard a very odd scratching noise. Looking down I was shocked to see the blade had opened again and this time cut through my jeans (goodbye to another pair) AND put a hole in my couch cushion. This is getting ridiculous now. I stopped carrying the knife. After a while I decided to try one more thing. I tightened the pivot beyond the torque that was set at the factory. The blade is a bit more difficult to open but....so far it has stayed shut. I am carrying it as I type this. There does not appear to be anything wrong with either the detent ot the lock bar strength but you are correct. I should probably just send it back to the factory for a closer look by the experts. Maybe there is an issue with this one.
What kind of pants were you wearing when those happened? I've noticed with thinner material mine can slip out easily, but thicker material--standard jeans, cargos, etc.--it holds better than any other clip I have because the seam of the pocket gets trapped between the where it screws in and the middle bump. The Mnandi is opposite; it grips thinner material well because the gap between its body and the clip is thin, but it is horrible with thicker material because as the material is wedged into the clip, the end, which has ridges to hold the material to keep the knife in place, flairs out so cannot grip the pants. So, I clip my Sebs and Zaan in jeans and pocket it in sport shorts and dress pants and do the opposite with the Mnandi. I have not lost any--I haven't even seen them shift slightly--but I still worry sometimes about losing one, so I ask to see if your experience contradicts what I do.
