un treated african blackwood for scales?
Im making scales for a texas toothpick ive made and I have some slivers of african blackwood and it seems a perfect material for me, im just wondering about treatments, the wood is dry(I got it from a Cabinet maker)do I need to give it a treatment before assembly to stop i warping and what have you?
African blackwood (sometimes called grenadilla) is a relative of Brazilian Rosewood and Cocobolo. Contrary to popular belief, it isn't related to Ebony, which is a different genus entirely. It is an extremely dense and somewhat oily wood, similar to rosewood - and definitely less brittle than ebony. Blackwood is used as a "tonal" wood in the manufacture of musical instruments.
I doubt it would stabilize very well, but I could be wrong. I definitely like the way it works with hand tools - very consistent and minimal tear-out.
TedP
have you any experience with it? as in using it for a handle for a hand tool? this word stabilize, its new for me.
I do not believe it needs stabilization.
Just sand to shape, and try buffing it. Lots of natural oils. Maybe a coat of Johnsons Paste Wax rubbed in.
Larry
Tinkerer
Ive the scales cut roughly to shape and sanded smooth and the finish is so nice on this material,I was reluctant to do anything at all to it, my hands get covered in black oily stuff that dyes the skin so I guess that's the oils ha!
I muse it all the time. It does not need stabilization, and from what I hear, doesn't take stabilization well.
Sand to 800 and buff to get a nice finish. Just like any good wood, avoid heat in sanding and buffing.
I've used it a lot too. Follow Bladsmth's advice and you'll be happy. I use pink scratchless to buff and then follow with a coat of wax.
I've used it a couple dozen times over the last 20 or so years... it's one of my favorite woods. It's one of the most dense (I believe it's 80+ pounds/cubic foot!!!), it has an excellent feel, it's a dream to work with (assuming you use sharp bits, blades, broaches, abrasives), even without being stabilized you can polish it to a near mirror shine (if you wish), its coloring goes with nearly ANY blade steel/style/finish, and it's a very stable wood.
For the longest time, I didn't think it could be stabilized, but my friend Chuck Bybee at Alpha Knife Supply has provided me with some blocks that were professionally stabilized. I'm not sure if he had it done at WSSI or K&G.
The only drawback to AB, is the color is so dark, it's hard to see the figure unless you have the knife in sunlight.
handsand to 2500 and you won't be able to put it down.
So shiny, and smooth, and, and, and :D
I have used both stabilized and natural blackwood. I can really tell very little difference. So now...I use it without stabilization.
When you purchase dense oily hardwoods stabilized, how can you be sure they soaked up any of the solution? You cannot. Even if they did, what good did it do but make them slippery?
This wood is excelldnt without stabilization. And it provides excellent contrast with micarta pins. It has a 'formal' feeling to it. Classy. (Big seller $$$)
You want to see figure in blackwood? Sheesh!!! :rolleyes: I want the jet black instrument grade stuff and if it does have some brown, I oil it until it goes away.:D For me, blackwood is the "substitute for ebony,the "color" more than the species, so to speak. It does work very well. I have tried the stabilized stuff once. It worked very well, but I don't really see the point.
First I want to say I like Joe M and consider him a friend.
With that said I will now disagree with him.
Natural Blackwood can show all kinds of wild looks.
I have had pieces that showed a metallic flash in silver, green and purple. Looked black at first glance until you moved it around in the light then the colors would appear.
Also there will sometimes be pieces with burl figure that shows itself with sort of a silver-ish flash.
Now to agree with Joe.
The black natural stuff polishes up beautifully and takes on a glassier finish than I have been able to obtain with ebony.
In my opinion it is one of the easiest Rosewoods to work and finish.
In old posts by Chuck B, I remember his comment that the figure disappeared in a burl piece that he had stabilized.
Talking to Chuck in person he told me that the Blackwood took stabilizing well and finishes with a nice satin look.
Mark, i know that it CAN show figure. I just don't want it to. ;) You know I love the rosewood family in general, but to my eye "lighter" blackwood is not nearly as attractive as its more reddish-brown cousins. I feel the same about striped ebony, without getting into why I hate to work the stuff.
But seriously, aside from being very attractive in whatever form you prefer, blackwood is, like the other members of the dalbergia family that we use is an excellent handle material not only for the customer, but for the knife maker who has to work with it. The only problem that you might run into is that you can develop an allergic reaction to some of the species.
this was just a quick mess about while i was waiting for bushings back from the machinist for the lockback whittler, glad I did it as I made plenty of simple mistakes as its been over ten years since I made a knife, the wood is beautiful material to work with,this could have been executed much better if I had taken my time a bit
Looks good squazy. I'd happily carry that knife in my pocket every day. I'm currently only doing fixed blades but would most definitely like to get good enough to work some nice folders sometime soon.
Chris
