Hi all,
The new EDC collection is out! Eight new little blades with colorful handles and leather sheaths with pocket clip. For the full spectrum of photos, please visit me at https://unboundknives.com/
You can contact me under: rusevknives@gmail.com
Thank you!
1. ''Patriot''
Dimensions:
Metric: OAL 160 mm, blade 75 mm, stock thickness 4,5mm
Imperial: OAL 6.2’’, blade 2.95’’, stock thickness 1.7’’
Weight: 80 gram, 130 with the sheath
Steel: Boehler N690 stainless, cryogenically heat treated – 61 HRC
Handle: Stabilized wood. tapered tang to save weight
Blade: Hollow grind, hand sharpened to a razor edge
Sheath: leather with pocket clip.
Price:155$ + 15$ international shipping
2.''Weird boy''
Dimensions:
Metric: OAL 155 mm, blade 70 mm, stock thickness 4,5mm
Imperial: OAL 6.1’’, blade 2.7’’, stock thickness 1.7’’
Weight: 99 gram, 152 with the sheath
Handle: Stabilized wood. Tapered tang to save weight
Price: 170$ + 15$ international shipping
3. ''Weird boy'' clip point
Dimensions:
Weight: 102 gram, 152 with the sheath
4. Pocket cleaver
Dimensions:
Metric: OAL 150 mm, blade 60 mm, stock thickness 4,5mm
Imperial: OAL 5.9’’, blade 2.3’’, stock thickness 1.7’’
Weight: 115 gram, 166 with the sheath
Handle: Stabilized wood. Glow in the dark resin
5. ''Ómega''
Dimensions:
Metric: OAL 150 mm, blade 65 mm, stock thickness 4,5mm
Imperial: OAL 5.9’’, blade 2.5’’, stock thickness 1.7’’
Weight: 75 gram, 123 with the sheath
6. ''Neon''
Dimensions:
Metric: OAL 145 mm, blade 60 mm, stock thickness 4,5mm
Imperial: OAL 5.7’’, blade 2.3’’, stock thickness 1.7’’
Weight: 70 gram, 114 with the sheath
Handle: Stabilized wood. tapered tang to save weight. Glow in the dark bead
Price:120$+15$ international shipping
7.''Harpy''
Dimensions:
Metric: OAL 170 mm, blade 80 mm, stock thickness 4,5mm
Imperial: OAL 6.7’’, blade 3.1’’, stock thickness 1.7’’
Weight: 94 gram, 143 with the sheath
Handle: Glow in the dark resin and carbon fiber. Tapered tang to save weight
8. ''Harpy hatchling''
Dimensions:
Metric: OAL 135 mm, blade 55 mm, stock thickness 4,5mm
Imperial: OAL 5.3’’, blade 2.1’’, stock thickness 1.7’’
Weight: 78 gram, 117 with the sheath
Handle: Stabilized wood and carbon fiber. Tapered tang to save weight
Thank you!
1. ''Patriot''
Dimensions:
2.''Weird boy''
Dimensions:
Dimensions:
4. Pocket cleaver
Dimensions:
5. ''Ómega''
Dimensions:
6. ''Neon''
Dimensions:
7.''Harpy''
Dimensions:
Dimensions:
