Unbound Knives SOLD
Feedback: +32 / =0 / -0
Hi all,
These are all for sale with original price dropped:
1. Puffin (green/orange) was 170$ is now 130$
OAL: 6.3 inch or 160 mm, blade 2.5 inch or 80 mm
- N690 stainless steel, heat treated with liquid nitrogen and tested by me - 62 Hrc
- Resin on the handle with carbon fiber pins and matching para cor d bead
- Hollow grind on the blade, sharpening angle is 17 degrees
- Leather sheath with belt clip.
2. ''Strider'' was 210$ in now 150$
OAL: 190 mm (7 inch), blade 80 mm (3.1 inch), stock 3.8 mm
Weight: 100 gram, 160 gram with the sheath
N690 stainless steel - 61 Hrc with cryo (tested)
Hollow grind blade, made on a 500 mm contact wheel
Stabilized curly maple with custom made color by Kalin Kalinux
Red G10 liner with carbon fiber pins
Matching para cord bead
Kydex sheath with belt clip
3. ''Love'' was 230$ now is 180$
- OAL: 220 mm, blade 110 mm, stock thickness 3,5 mm.
- N690 stainless steel, heat treated by me with liquid nitrogen and tested - 63 Hrc
- Stabilized american maple by Kalinux with tapered tang for balance and to save weight. Mosaic pin.
- Full flat grind on the blade. Sharpened to 17 degrees. Hand rubbed satin finish.
You can contact me at rusevknives@gmail.com or here
Best regards,
Nick
