Well, got my Case pocket worn stockman in mediteranean blue today. It's not perfect, but then again it is a mass produced knife, not a handmade custom.
The good.
No blade rub, all 3 blades fits neatly and tightly in there. Fit on the spring to spacer and bolster is just about perfect, can't see the light of day in between, so are the scales. The pull is quite light, but smooth, and no blade play. Grinds on the blades are smooth and even. The inside of the knife is clean, it's also a quite attractive knife if I may say so.
The bad.
Firstly, none of the blades cut at all, so it can't be called a knife until I sharpen them; the main blade even has a gigantic burr all along the edge. Then when they made the jigged pattern on the handle, they hit the bolsters in 3 places; it's not shocking, it's barely visible depending on the light angle, but I'll always know it there. Lastly, one of the blade pivot pin is visible in the bolster; again, not shocking, but I'll always know it's there.
For a user knife, it will more than do the job, so it's a keeper.
