I have the vfd installed and programmed and ostensibly it works. Ive tried it on a centrifugal switch buffer and the start/run cap grinder motor. It will run both at variable speed.
That said, the buffer in particular has no torque under 45hz. The grinder has significant torque loss as well. I haven't read through all the parameters but did increase the anti stall comp, it did not help. Haven't found a torque comp setting yet.
Now, ignoring the buffer, on this 2 cap grinder motor, should I disconnect the run cap? Jumper past it? Maybe both? I can play around with it but curious what you guys think. For how I use this horizontal grinder I can use it as is. But I can hear one of the caps clicking in and off when I slow it down by hz or just by stalling.
It's also not very responsive to freq changes under 40 hz. Requires 30 just to start turning.
As it stands this might work great for a brushed motor but unless i can figure out how to get more torque and better frequency response at low hz i don't think it's a solution for a belt or disc grinder.
I'll play around with it some more.
