Ever since I was a little boy I would gaze in amazement when I saw my
fathers switch blades, and balisongs. With there ability to quickly deploy the blade faster then any of my folders at the time. I always have been interested in Stiletto/Daggers above folders but when I see a unusual folder I can't help but grab it. so show me some pictures of non traditional folding blades that are "unique" being released from force,gravity,tension,leverage
Anything that requires one hand to open, or is just plain unusual. No spring knifes please!
Here is some of the more popular I have seen.
Balisong/Butterfly knife
A knife when in a closed state will conceal the blade between two handles,
That pivot or swivels around the blade with a bit of practice you will be able to open it with one hand.
Cold Steel Triple Action
The blade on this pivots like a folder the handles are like a balisong but,
pivots in the opposite direction of a balisongs handles. Slide the thumb stud
and the flick of a wrist the blade is revealed!
The handle falls back into position giving a "Balisong type"
locking mech.
(There is also a video you can find on there site to get a better idea)
German gravity knife
This type of knife uses gravity to deploy the blade.
Holding the blade down, and pushing or flipping a switch will release the
blade.
Janisong
Not yet released to the public, This knife is based on a balisong
With safety in mind. Being able to manipulate it like a balisong without
The risk of getting cut and the ability to have a blade if required.
The way it works is when the blade is released from the side a
"Blank" blade deploys covering the edge of the blade. There is a video
demonstrating the knife in action.
S&W Power glide/Paratrooper
This knife has a "scissor like" deployment opening the handles
and then closing them will deploy or retract the blade
there is a trick to deploy the blade with one hand
Edit: I have found two more to add!
CRKT Glide Lock
on the upper part of the handle is a piece attached to the blade tang, pushing it up
will unlock the blade so you may swing it open, pushing the piece back down will lock the
blade in place.
CRKT The Snap Lock
this one is somewhat wierd
a "thumb stud" is pressed to unlock the blade, with substained pressure on the stud will
"fold" the blade out of the handle.
locking mech.
blade.
Janisong
CRKT Glide Lock
blade in place.
CRKT The Snap Lock
