- Jan 12, 2016
So I have a customer who is my guinea pig whenever I get a new steel in or have a style I want to try out. He loves the deal because all he pays for is 'materials and I gain the experience without much loss. He approached me this evening stating he has a couple flaws in one of the knives I've made and wanted to bring it to my attention. The knife is a lime cutter I had made because I had just enough left in the bar of 440c to pull it off. When he received it I pointed out the one line caused by turning the blade into the platen when grinding, no problem. The flaws he is seeing now is chips in the bevel 1/3 and 3/4 the way up the grind. Now when I was finishing it I did a very thorough check with 5x magnification to check for any stress marks or cracks and found none. My worry is due to I did my HT in a forge vs, an oven I wasn't able to retain the soak at a constant temp and caused microscopic cracks when I quenched. The only other thing I can think of is when grinding because my shop was maybe 35deg that I cooled it too harshly it my water tank from the heat of the belt. I have not yet seen these chips and wont for a few days but I would like some sort of what may have happened before hand since Ive known of this for only a couple hours and its haunting me. I will take literally any insight because other than the stated possibilities I'm stumped.
