I don't know how deep into the metalurgy you go, but here is an interesting paper on D2 - if you're into such things (an excerpt below)
1.7
D2 tool steel used for cutting purposes operates under conditions of impact, where resistance to mechanical damage is desired.
Due to high carbon and high chromium content, the Wear resistance of D2 tool steel is approximately eight times that of plain carbon steels (25).
The chemical composition of D2 steel is usually: C-1.5%, Mn-0.30%, Si-0.25%, Cr-12%, V-0.60%, Mo-0.80%.
Kligler (26) has shown that the mechanical properties of D2 steel are anisotropic and depend on orientation with respect to the rolling direction.
Both strength and ductility, as measured by tension, compression and bend tests were found to be maximum in the direction parallel to the rolling direction and minimum in the direction transverse to the rolling direction.
This directionality of mechanical properties can be attributed to the production of elongated carbide stringers in the direction of rolling.
The dimensional changes resulting from hardening of high-carbon high-chromium steels are exceptionally small.
Previous research (27-29) showed that an 11.00% chromium steel of this type expanded only 0.1 % of the annealed volume after hardening in air.
Although the majority of applications of D2 tool steel involve cold work, it is also widely used for hot trimming of forgings.
Typical applications include blanking dies, slitting cutters, shear blades, forming dies, knurls, gages (plug and thread), punches, trimming dies, etc.
https://tspace.library.utoronto.ca/bitstream/1807/13366/1/MQ45596.pdf
(for the whole paper)
Please share results if you do work it for hard use, and your HT... it sounds like 3 tempers gives a worthwhile result increasing toughness
