Hello all,
ok just had an idea for a search and rescue knife and i have some ideas how to go about it but i just want to know what everyone thinks of the practicality or fabrication and use.
this knife could be used for any field but it would be a go to knife for S&R.
basically the whole issue i see with using a knife in S&R when it gets down and dirty is closing or re-sheathing the knife. so why not combine the 2. the idea is to make the knife to do what ever you need then make a sheath that would not block the cutting edge as the protection from the blade but come down on the knife to prevent from coming in contact with the blade. the idea i have is to make a u shaped sheath where the blade is at the open side of the u, it would spring closed and lock in place with an easily activated toggle that would also spring back to lock if the knife is dropped or grip is lost. the sheath would move up and down along the short dimension of the knife.
the idea would be to grab the knife, pull the toggle back (im thinking along the spine with the users thumb) they would then push the knife against what ever needed to be cut and then, once any material is no longer in contact with anything, the sheath would travel back down to cover the blade. while the knife would not be ideal for cutting through thick items it would be fine for cutting rope or seat belts and protect the user and rescue victims from getting hurt if they were to fall or the knife fell from the rescuer's hand.
make sense to any one?
think it would work?
is it doable?
-matt
is it doable?
-matt
