Hi Guys,
I was hoping someone might be able to solve a problem I am having with the knife I have just finished making.
Basically on completion of my knife ( Frame lock folder) the two thumb studs were sitting perfectly flush against both sides of the handle.
The thumb studs came loose so I took the blade out and used a special thread lock glue to prevent the thumb studs from coming loose. The thumbstuds are tight, straight and flush on the blade. However, now when I re fit the blade only one of the thumb studs is hitting the handle. The thumb stud on the frame lock side is about one millimeter off the frame, so only one of the thumbstuds is actually stopping the blade on opening...
I have since taken the knife apart and re assembled it numerous times. I have checked everything! - I am absolutely bamboozled as to what has gone wrong, and it is really annoying me as it defies logic!
I am hoping someone may have an Idea of what the problem could be.
PS. Is it a safety concern that only one thumbstud is stopping the blade? It still seems very tight ( they are heavy duty studs )
Cheers
Suva
Cheers
Suva
