- Nov 1, 2000
possibly in a larger (4"+ blade) design of the Manix 2.
I second that. Perhaps hollow ground?
I don't buy any of that reasoning.
As to the reason for the CBL, I was under the impression it had more to do with user operation, the regular BBL being difficult for some users to operate. The CBL is easier to operate based upon what my friends are doing when given examples of the respective knives for an opinion.
The Manix 2 frame area and the P'Kal's is a bit thinner than 710. Overall the knives are close enough in thickness as not to matter once the clips are taken into consideration.
As to width, top to bottom when closed, that has more to do with the blade width - a design difference that has little to do with the lock design. Also, that hole is a design driver that results in a wider knife in many instances - get rid of the hole and use studs and one could make a pretty narrow knife. Of course, then it wouldn't be a "Spyderco" - I suppose a token hole could be used.
As to a future sprint run, I'd be pleased with an M4 version as the Mule is an impressive blade - a Manix 2 in M4 would be my folding version.![]()
Make the S90V Manix2 a regular production item, just like the Orange Millie.
Then we can all have one.
I know you didnt mean that with all your heart. Even if they could do it, that would be lame.
I like the Smaller Runs,Spyderco offers PLENTY of something for EVERYONE! Its nice to see the SUPER NICE STUFF in Limited Runs. Hope to see more offerings like this in the future, thanks Spyderco.
If you look inside the Manix 2, you can see the lock ball is only about the size of a BB. That would be really tough to operate without the cage, which is why it is there. I followed the developement of the P'kal as closely as possible without being an insider. These are things Sal mentioned during that time, often in response to people wanting to know what was taking so long.
You may not buy that reasoning, but that doesn't make it untrue.Take a Dodo, a Poliwog, a D'Allara and a P'Kal or Manix 2, open them and lay them all down side by side. Look at where the pivot is located on each. Then close them all and look again. The design of the ball lock pushes the pivot point off-center in the handle, and it pushes it away from the spine. What happens when you do that? it makes the closed knife wider. (An excellent example of this can be seen with the Benchmade Boguszewski Spike using a liner lock and the auto Spike using the plunger lock) The bigger the ball is, the farther it pushes the pivot off center. Making the ball smaller allows the pivot to be closer to the centerline of the handle, which reduces the closed width of the knife.
That is the clearest illustration of my point that I can make, so I will leave this thread to you now.
