I hadn't seen this knife before, i'm a little confused on how it operates. I see it still uses omega springs, or were they just there for the assisted opening?
How does the axis bar lock manually?
It is still an axis lock. When you push the button(s) it raises a lever that in turn kicks the axis bar back, just as if you where pulling the axis bar back on a normal axis lock knife. When you engage the lock, the button(s) cannot be pushed in. It is quite a feat of engineering. I don't even know what is going on with the pivot. That part is above my paygrade. Perhaps Keyman could explain it better.
The detent on this thing is just like other axis lock knives but it seems a little stronger to me. And once again when the lock is engaged the buttons can't be pushed in to allow the lever to let the axis bar be pulled back. The big hit on the original axis lock for me is the weak detent. Not with this one. It can be locked open or closed.
Hopefully more people will pick this up and de-assist it.
No that's not how it works.Interesting, looks fairly complicated from the pics. So you open it with the thumbstud and then push the button to lock it open, and then to close it, you push the other side of the button to disengage the lock?
I'm used to the normal axis lock where you can grab the axis bar and open or close, I guess that's why I cant really figure out how this new one works.
Anyway thanks for your patience.
To put it in your words:I'm used to the normal axis lock where you can grab the axis bar and open or close, I guess that's why I cant really figure out how this new one works.
The knife opens just like any other axis lock knife, just us the thumb studs.
When you want to close it; instead of pulling back on the axis lock to disengage the lock......you just push the button(s).
In short....the action of pushing of the button(s); replaces the action of pulling back of the axis bar.
Simple as that.
In addition, the 665 has a safety that can be engaged to lock the blade in the opened position or engaged to lock the blade in the closed position.
Super simple...easier than an axis.
craytab is right...it's super fun to play with.
Not quite. Pushing the button (either one or both, I like both) is exactly like pulling the axis bar back on a normal axis knife. This is in fact what is happening on the inside. The locking part is completely optional. It can be locked open or closed. The lock blocks the buttons from being pushed in and I just noticed it slips behind the axis bar which does not allow it to be pulled back. It would be like shoving something behind the axis bar of the regular axis lock, either when open or closed.
It really is just an axis lock that is mechanically operated. That is the best way to conceptualize it.
Ah I understand, very cool. Sounds like I would like it a lot!
I get it now, I think I would like to give it a try. Especially if the pivot is simpler to adjust in that you just tighten it all the way and centering and play is perfect, I've never owned a sebenza but I think I've read that sebenzas are very much like that. kudos to benchmade!
Thanks for disassembled pics and explanation how this lock works.
In mechanical watches they call additional functions "complications".
It seems to me with this lock being basicly same old Axis lock,
it just has additional maybe unnecessary "complications" that can fail/jam/break,
button that moves Axis lock bar open/close instead of using finger!
I never had regular Axis lock fail to stay close or open for me yet.
Than again I don't do crazy things with folders that they were not designed to do! Ex: batoning, hitting spine on hard object etc.
What he said 100% :thumbup:.This knife is a pure joy to use.
I've really been on the fence about this one. Thanks for all the pics and the writeup; knowing it can be deassisted helps for sure. Is the black coating the same as what the Grips use or is it cerakote like the 810?
I believe it is like on the grips. Neither one is particularly resilient.
