Update of my Review of the Apex
Okay, the long-awaited update on my review of the Apex sharpener is done! I hope you find the information to be useful and if you want to read the original review check it out: http://www.bladeforums.com/ubb/Forum3/HTML/001223.html Ben Dale (the maker of the Apex) is at: http://www.gorge.net/business/edgepro .
Differences between the Old and New:
The primary differences between the Apex I now own and the Apex I had a loan of are few but significant. First, the body is now injected nylon rather than ABS plastic. This means that the body is more rigid and there is no flex apparent when sharpening. Second, the suction cups are now of a softer material, allowing them to adhere, and stay so, far better than the previous models. In the original testing it was not uncommon for the suction cups to let go after 10 or 15 minutes. After 4 hours of sharpening with the new Apex I did not have to re-attach the suctions cups once. Third, a brass riser block is now included to facilitate in the sharpening of chisel ground blades. Fourth, an 800 grit ceramic steel is included. And, finally, the new Apex has a wider variety of stones: 100, 180, 220, 320, 600, and 3000. The 3000 grit is not actually a stone, but a tape, which adheres to the back of a stone blank.
Performance:
Over the past few days I've had the time to really improve my skills with the Apex (I will not describe the actual use of the Apex as that was already covered in my initial review and none of that has changed). I've sharpened the following knives:
Benchmade 710 (ATS-34)
Benchmade 720 (ATS-34)
Benchmade 750 (ATS-34)
Benchmade AFCK (ATS-34)
Benchmade Stryker (ATS-34)
Benchmade Sentinel (ATS-34)
Cold Steel Bush Ranger (AUS-8)
Microtech SOCOM (154-CM)
Spyderco Howard Veile (AUS-8)
Spyderco Starmate (440-V)
I sharpened all the knives the same way (started with the 100 went all the way to 3000, the angle was set to 21 degrees) and achieved identical results. All the edges had a mirror polish and all passed the following tests for sharpness (they're not all scientific, but they're all fun):
Slicing cigarette paper cleanly (both directions, the paper has a "grain").
Slicing a sheet of free-falling paper cleanly in half (this became more difficult
with some of the shorter blades-720-but was possible nonetheless).
Slicing a roll of paper cleanly (roll a sheet of paper up until the diameter is about
an inch and a half, tape the ends so it doesn't unravel, place on end, try and slice through).
Shaving hair.
I decided to start at 100 grit in order to ensure the angle was uniform. In order to create a truly sharp edge both bevels must be perfectly flat. If you take your knife and angle the edge in the light you should NOT see a fine reflective edge. If you do your bevels are not flat and therefore you do not have a truly sharp edge. The edge of a knife should be virtually invisible. The other reason for starting at 100 grit was to even out the grinds. I quickly found that almost all of my Benchmades had uneven grinds. One shoulder was higher than the other was, or the angles were not the same on either side, or both. The Cold Steel Bush Ranger was fine, so were the Spydercos and the Microtech. The time it takes with the 100 grit to get the bevels uniform is well worth it. After setting the bevels each knife required approximately 15-20 strokes per side with each grit to reach a mirror polish. The simple fact of the matter is that no amount of grinding with a 600 grit stone is going to do what 100 grit can. Use the 100 to do all the work, use the others to polish. Also, when it comes time to re-sharpen, because you took the time to but on a proper edge a couple of strokes with the 600 and 3000 grits are all you need to get that mirror polish back.
That's the secret of the Apex, polishing. There are two main ways to get a sharp edge, grind a sharp angle or polish the edge. I used to have my knives at 20 degrees (done on a Spyderco 204) but decided they weren't sharp enough. I then sharpened them at 15 degrees and got a sharper edge, but it didn't last. The finer edge cut more easily, but wore down and rolled over with equally increased ease. My knives are now set to 21 degrees and by polishing the edges smooth they are now sharper than any knife I have EVER owned and the edges LAST.
In sharpening the above knives I had no problems except with the Benchmade 720. The hollow grind is so high (you could argue that it's really almost flat ground) that there isn't enough flat by the spine of the knife to support it when sharpening. The solution was to lay the 720 on the ground section and adjust the pivot up one setting. This gave me the desired angle with no further problems.
One important note is in regard to scratches. Scratches can occur using the Apex, however the source of the scratches is often mistaken. The stones DO NOT scratch the knife, the slurry does. Slurry is the name given to the mud that forms when using water stones. It is composed of water (the lubricant) and particles of the water stone that are ground off when in use. This slurry gets between the blade and the knife blade table. As you move the knife the slurry scratches it. The solution is simple-blue painters tape. I put a strip across the knife bed and on the contact areas of the knife. Of the above knives, NONE of them received ANY scratches while using the painters tape.
Conclusions:
As in my original review, I still believe that the Apex is the best sharpening system I have either seen or used. It produces perfectly flat and uniform bevels and brings them to a mirror polish. That polished edge is phenomenally sharp and stays so longer. A rough edge has micro-serrations that catch and tear as the blade is drawn through material. While this does give the knife a certain aggressive cut, it also precipitates the dulling of the edge. The micro-serrations tear off of the blade or go out of alignment. A polished edge has little to no serrations so the edge is not subjected to such tearing. And if anyone is wondering if a polished edge will cut as well as a micro-serrated blade, I think it does. I took a strand of 3/8" polypropylene rope, looped it over itself 4 times and then cut all 4 strands in one stroke. I did that with the Benchmade 720; a knife with only 3 3/8" of blade. In my opinion polished blades are the way to go and the Apex is the way to get them.
Corrections:
I'm adding this to my original post to make a correction. It has been pointed out to me that I didn't clearly explain what comes with the BASIC Apex. The Apex comes with-180 and 220 grit stones. I then bought the UPGRADE kit which has-320 and 600 grit stones, the 3000 grit tapes, and an 800 grit ceramic steel. I also bought a 100 grit stone. The riser block is available by request. I'm sorry if I didn't make that clear in my intitial posting. If there was any confusion about what came with the Apex, I apologize.
"Better to reign in Hell, than serve in Heav'n"
John Milton
There are only two types of people; those who understand this, and those who think they do.
[This message has been edited by Johan (edited 01-23-2000).]
[This message has been edited by Johan (edited 01-24-2000).]
sounds like a great sharpener...but is it really worth the money when for one third the price you can get a lansky that works "just fine"?
In what was destined to be a short-lived spectacle, a chicken, suspended by a baloon, floated through the Samurai bar's doorway
IUBI, that's a valid question. The Apex is certainly not cheap. The best answer I can give is this: If you're getting the results that you're happy with from a Lansky, then stick to it. I've used sharpeners from Spyderco, Gatco, Lansky, plus a variety of "V"-type sharpeners as well as bench stones. None of them gave me the results that I wanted for my knives. The Apex did. I looked at it this way the Apex cost me about $150 US, my collection of knives is over $2000. 7.5 % of my collection's worth isn't much when you think about it. That being said, I'm a freak. I want my knives to be razor sharp all the time. Period. Perhaps I'm biased
John Milton
$275.00 ouch! That thing better get my knife sharp enough to make the hairs on my arm plead mercy! I give credit to whoever said that first. Man, looking at that price i start thinking about what knives i could buy with that money. Ummmmmm Busse Battle Mistress. Oh well, i guess it depends on how important that level of sharpness is to you. looks pretty dern cool though.
Andrew
I also have an Apex, and agree 100% w/Johan's review...It works great, and I can get much sharper edges than with a Sharpmaker or Lansky, though I'd say it's all a bit operator-dependent...As for Benchmades...EVERY one I have sharpened on my Apex has had bad bevels. I even sent my Axis to Edge pro before buying my Apex, and he concurred; BM knives have lousy factory edges...Spyderco seems to have the most consistant edges, but to each his own, i guess..
--dan
Actually RenField it's only $220 Canadain, a Battle Mistress would be over $500 Canadain. I know, I'm a big Busse fan
As for, "That thing better get my knife sharp enough to make the hairs on my arm plead mercy!", you can actually each each hair go "ping" as you cut, is that close enough?
John Milton
Very good review Johan! I really like my Professional Edge Pro....if there is a better sharpener out there I want to know as I'll buy it!!
Ok, I beleive the Tormek is a much better sharpener. If you think the Edge Pro costs alot then forget about the Tormek.
Alright, what is a Tormek sharpener? I also have the apex sharpener and agree 100% with the review - nice job by the way. I am having to flatten the 180 and 220 grit stones fairly often as I am sharpening a lot of knives. The benchmade bevels are driving me nuts too, they can take a lot of work to get even. I wish there were options for diamond or ceramic stones of the same height and dimensions of the natural stones. I am thinking of trying the dmt trick, but would prefer not having to change the angle between stones. I get much sharper edges with this system than I ever got using Lansky, Gatco, Sharpmaker or freehanding on hones.
I as well would like to know what the Tormek is. Snoopy as far as the 100 and 180 stones go, flattening them is the price you pay with water stones. They cut quickly and they wear quickly. Ben estimates the 100 will sharpen 20 knives before it's worn too much. I consider this a price worth paying. As for the diamond stones, Ben says if you can get them in 1/8" you can stick them to a blank and you won't have to change any of the angles. BTW, I'm glad you liked the review. I do my best to give informative and relatively unbiased reviews.
John Milton
One problem I seem to have is that many folders have just a little flat area and are hard to hold flat on the platen. Is it better to set them down on the hollow ground edge? This one area that systems such as Scarb or Lansky that clamp the blade have an advantage, or am I missing something?
As far a waterstones go, I prefer the edge I get from them. I use diamond stones to flatten them. Diamond stones cut faster but they "burn out faster", actually the diamonds seem to come out of the substrate. As the grades get finer I think waterstones give a better more uniform edge. I have been disappointer with 1200 grit diamond stones including DMT.
Roger Blake
Johan,
After I saw your initial review, I have been looking at the Apex. I was wondering if you used it to sharpen any serrated blades. The maker's web page states that serrations aren't a problem, but I only saw flat stones. Haven't contacted the maker yet, but if see anymore favorable remarks about this product I don't think I'll have a choice.
fortuna favet fortibus
db, thanks for the link I'll check it out.
Beam, I know what you're talking about. Believe it or not you don't really need a lot of material to get a good hold. The trick with the Apex is NOT is press hard. However, I do have a couple of knives with really hollow grinds. In that case you do have to lay the hollow on the knife table, raise the pivot up one setting and that normally compensates for the change in angle.
AKshooter, Ben says that he sharpens the backof serrted blades only, just enough to start a very slight burr. It can be done although I have to admit I've never tried it. For serrations I prefer my 204. And if you've got any more doubt's sned an old pocket knife to Ben and he'll sharpen it for free just to show you what the Apex can do.
John Milton
I too have an Apex-1 with the optional stones. It is without doubt a fantastic unit. But, although mine has only seen minimal use, the rubber cups seem to hold fine. I also use either a bit of felt cloth or thin leather to buffer the aluminum bed from highly polished blades.
I guess my only lament is that I must be getting lazy in my old age. I just don't take the time to set it up unless I've got several pieces in r-e-a-l need. It's still too easy to grab a stone, strop, or steel for quick touch ups.
-=[Bob Allman]=-
I did NOT escape from the institution! They gave me a day pass!
BFC member since the very beginning
Member: American Knife & Tool Institute; Varmint Hunters Association;
National Rifle Association; Praire Thunder Inc.; Rapid City Rifle Club;
Spearfish Rifle & Pistol Club; Buck Collectors Club (prime interest: 532s)
Certified Talonite(r) enthusiast!
[This message has been edited by bald1 (edited 01-28-2000).]
Here I am struggling with the Spyderco 203 on my Livesay Air Assualt http://members.tripod.com/~Newt_Livesay/mdl131Air_Assault.html and am about to start slamming my head into the wall as the knife is not getting much sharper.
As I'm such a novice when it comes to putting a good edge on a blade is the Apex the way I should go or is there a better way to learn how to sharpen??
What do you mean when you say the stones need to be flattened and how do you do this???
Does the edge the Apex puts on the blade stand up to lots of use and abuse without constantly needing to be re sharpened??? Some places I've gone and will be going it's impossible to take and use the Apex.
How does the Apex compart to Lansky and Razor Edge systems??
[This message has been edited by Shrike9 (edited 01-28-2000).]
Shrike9, Allow me to direct you to this thread.
http://www.bladeforums.com/ubb/Forum32/HTML/002622.html . It should answer a few of your questions, quite a few different systems were mentioned. If you would like any more information concerning comparisons between Edge Pro, Lansky, and Spyderco
e-mail me and I'll help you out as best I can. These are the only three I have personally owned and used, so if you have any questions about other systems I can only pass on second hand information. Hope this helps.
Just because I talk to myself does not make me crazy. Now, when I listen to myself, that makes me crazy.
[This message has been edited by Roadrunner (edited 01-29-2000).]
Shrike9, good questions let's see if I can't answer them all
"As I'm such a novice when it comes to putting a good edge on a blade is the
Apex the way I should go or is there a better way to learn how to sharpen??"
I think the Apex is the best way to put an edg eoon a blade for a couple of reasons. Technically you want to have your edge consisting of two well-defined, flat, even, and equal bevels. The Apex does this with ease. There are cetainly other ways to sharpen, but they're not for me.
Benchstones-Knives can certainly be sharpened free-hand on benchstones, but the trick is maintaining the angle on both sides. That's something I've nevver been able to do. Could I touch up a blade free-hand? Sure. Could I regrind free-hand? No. Some people can do that, but I'm no one of them
Lansky type sharpeners-Some people swear by them, I just swear at them. If the clamp isn't set in the same place everytime, you get a slightly different angle everytime. To work a large blade, you have to unclamp, move, reclamp. And make sure the clamp it set the same each time. Not for me.
Spyderco 204-Great system, used it for years, use it still for serrations and touch up. The problem with the 204 is that if you don't ALREADY have an even edge, it won't sharpen properly. You'll end up sharpening one bevel only and being unable to remove the burr from the other side. Once you got the edges, the 204 works great!
"What do you mean when you say the stones need to be flattened and how do you do this???"
Water stones cut far more quickly than oil stones. The trade off is that the stones wear more quickly (unevenly too) and need to be flattened. All you do is sprinkle some sand on a sheet of glass or on a concrete floor (as long as it's flat) or use some 120 wet-dry sandpaer and just grind the stones for a minute of so. That flattens them and you're back in business.
"Does the edge the Apex puts on the blade stand up to lots of use and abuse without constantly needing to be re sharpened??? Some places I've gone and will be going it's impossible to take and use the Apex."
Although I haven't been able to run and really long term tests, I do believe that the Apex edge will last longer than everyone thinks. By polishing the edge you remove microserrations from the edge. These microserrations have some benefits, but more disadvantages IMO. They catch on the material you are cutting and come out of alignment or tear off. Think of a splintery board, if you rub something against it you tear off the splinters, same sort of thing. A polished edge has no microserration to catch and be torn off. Theoretically, such an edge should retain it's sharpness longer. So far, I have found this to be true. I'm working all weekend, so I'll try some tests next week and post.
The Apex isn't overly transportable and I certainly wouldn't carry it with me on a camping trip. My advice is to get the edge with the Apex, and then maintain the edge with a 204, or if that's too big, something like a Gatco Triseps.
I hope I've answered all of your questions, but if not email me and I try harder
John Milton
Johan,
First of all, very nice review - couldn't have done better myself. I do have one question/comment tho. When there's not enough "flat" to lie the knife down on the table, you would lie it on the hollow - how do you determine the amount of compensation for the angle adjustment? You stated that you "increased the angle one setting". Does this mean increase the angle, i.e. from 20 degrees to 21 degrees? or from 20 degrees to 19 degrees? Is one degree enough or maybe too much? I own an Edge Pro professional and I love it but a lot of my folders do not have enough "flat" and it's difficult to maintain a precise angle on both sides.
Thanks.
Steve
[This message has been edited by skhori (edited 01-29-2000).]
Skhori, I know what you're talking about. My BM 720 doesn't have enough flat so I have to use the hollow. I spoke at length with Ben about this and he recomends adjusting the pivot by one setting, that equals a change of 3 degress (the pre-set angles on the Apex are 10, 15, 18, 21, and 24 degrees). That is enough to compensate for the change in blade angle relative to the blade table. I found that that works nicely. I just made a note of the angle for future reference and that was that. If you want to maintain the angle EXACTLY as it is, use the marker method. Hope this helps. As with all my replies, if there are other questions or something I missed, please let me know.
John Milton
