Well I had a busy weekend in the garage. I feel good about what I got done, but it never seems like enough. I am eager to get it all done.
The grinder I purchased is 3 phase. When I realized it was a 1hp 3 phase motor, and that it matched my mill motor. I realized I can run both the grinder and the mill from the same VFD. This needs to be mounted in a Hoffman box and service cables run from it.
This is the motor. The carpenter I purchased this from said the motor to the grinder was burned out. So I hadn't really tried very hard to get the grinder done yet.
When I noted this old knife edge switch, and the carbon arc'ing burns on two of the switch contacts I decided to check out this "burned" motor.
So with the switch out of the motor service box, I used my multi-meter to examine the contacts. This one doesn't look good at all.
This one is done for, and this switch is most definitely bad.
So with the switch as the problem, time to check if it killed the motor. This nine lead motor is wired for high voltage right now, but I can still check the windings. I am measuring the resistance across all three windings. This will tell me if the winding is complete, shorted turn to turn, and I also checked for shorts to ground (which is not photographed).
I decided after reading another thread about quench tanks, that I would try my own idea and use an out of date SCUBA tank. An experiment in action I guess. The tank is about 15 years out of hydro.
