Erin Burke
KnifeMaker...ish
- May 19, 2003
Hey guys,
I just bought another 2hp motor to set up a dedicated 9" disc grinder station. I will be installing a switch on the output side of my KBAC-27D vfd -- which currently controls only my KMG -- so that I can run both motors from one controller. Currently I run an 8" disc off the back of my wood-lathe headstock. I'm excited for the larger disc and the reversibility that I'll get from the new setup.
As mentioned, I currently run an 8" FLAT disc. I have heard several folks recommend going with a 1-degree bevelled disc which helps avoid grinding on the uphill and downhill sides of the disc at the same time. Are there any down-sides to the 1-degree bevelled disc? Are there any compelling reasons to have both 1-degree AND flat 9" discs? I realize that 1-degree is a fairly insignificant angle... but does it get things dead-nuts flat enough? There are a lot of folks that I respect who use the bevelled discs -- including Mr. Wheeler (a stickler for flat-flats) -- so I'm inclined to think that I should be able to get away with a 1-deg disc only... but I'm willing to listen to other opinions.
Thoughts?.?.
Erin
Thoughts?.?.
Erin
