After reading all the positive posts about the Craftsman 2x42 grinder for beginners, I managed to pick up a used one off craigslist for $35. It didn't come with a platen, and I'll buy a replacement from Sears. More importantly, it makes a strange noise when I run it.
The noise is like a set screw bouncing around in a tin can. I'm fairly sure it isn't bearing related, because if you stop the grinder by hand it will continue to bounce around for several seconds.
How worried should I be about this? Should I just consider it a disposable grinder? It doesn't look straightforward to take apart, but if I'm likely to be able to fix it by doing so, I'll try. Is it worth disassembling?
Thanks,
Alex
Thanks,
Alex
