ManOfSteel
- Nov 8, 2005
MT Scarab, '03 production, satin serrated. Light use, never sharpened, still factory sharp. Original tube, sheath, papers, etc. I started to mod this one by leveling the high spots on the frame to the same elevation as the abrasive inserts with a belt sander. Never found the time to finish the grind with fine grit. The contrast looks good with the satin blade. It will look awesome once someone finishes it. This is the hardest hitting, tightest lockup of any Scarab that I have owned.
Looking for a large classic user Seb. Marks are not a problem. Sharpened is not a problem if you did it right. Broken in to thumb open more smoothly is a plus. Inlays are a plus. Might consider a regular, especially if it is graphic. Blade play or stripped screws are about the only negatives I can think of.
Drop me a line for pics if you are interested. Thanks.
