Ed, you can do this yourself by doing the following;
1. Click on "User CP"
2. Select "Edit Profile"
3. Scroll down to "Custom User Text"
4. type in "Usual Suspect" or whatever you like
5. Scroll to the bottom and click on, "Submit Modifications."
Either I am having an attack of the dumbs or you need to be a Moderator, as I cannot find the field that you are refering too. I can see the place to change your signature line, but not the field to change Gold Memember to Ususal Suspect.
I think you're having an attack of the dumbs (happens to the best of us) -- but maybe more detailed instructions can help. After you've clicked on "user cp" and then "edit profile" and scrolled down a little you'll see a box that looks like this on the left:
Custom User Text:
This is the title that appears beneath your name on your posts.
You may enter up to 25 characters.
Check the reset box if you wish to use the default title for your usergroup and post count.
HTML is not allowed.
And like this on the right:
Current title:
gold member
New Title:
Reset?
Right under "gold member" and after "New Title:" there's a box for you to write in your new title. If you were to check the box for "reset" it would reset your title back to the default for your membership class, which in your case is gold member -- so don't check that box; just type "usual suspect" in the new title box and you should be all set.
The option of changing your title is not available to basic members, but all the paid members have it.
I was afraid of that. I'm figuring I'll keep checking this forum while Spark is away and try to fill in, but all I can do is explain things; can't fix bugs even if I knew how since I'm 2,000 miles away from the server. If you still can't find it, it must not be there for you -- I can't imagine why.
Ed, you are not alone. When I go to edit profile, I can find no mention of custom user text. All I have is registration, required, optional, signature, additional and submit. I have no info regarding membership at all. Jeff
Kevin
Actually I didn't have anything in mind, I was going to play with it until I tripped the light...
Thanks for the response though. If something occurs to me I will ask again. Thanks
