Using AKS .187 bearings for bearing pocket. Counterbore vs. Endmill
Josh Rider
Stuff maker
Just wondering which to buy. I bought some .187 bearing cages from alpha knife supply. For anyone using these, which tool and process would you recommend. I have a mini mill.
I don't have a rotary table. Was wondering about plunging a large enough center cutting endmill, if that would be accurate enough.
With a Mill you can plunge the recess but it takes a 10MM center cutting end mill.
I use these and use a 13/32 4 flute Altain endmill center cutting, I have 2 rotated tables but don't use them for the counterbore, I just plunge cut and have never had an issue.
You can use a 25/64 as well, I have those too, I just prefer the bigger endmill.
I actually use endmills on my centering jig instead of counterbores, I haven't had an issue with concentricity but that is due to my process.
Thanks for the replies fellas.
Mike, is the centering jig something you created?
Thanks for the endmill suggestions
I made the jig, it's fairly simple, it basically just replaces the pilot in the CB. Many ways to do it without a jig though. You will find getting a custom CB for the 3/16 is a pita, especially if you want carbide.
The end mill is a funky size, I spent the better part of an hour with a set of calipers digging through bins at my local tool supply until I found one close enough. I just plunge with it. I've also found that having your parallel directly under the hole makes a cleaner pocket, just what works for me.
Cool, Thanks for the tip!
