Using an Arbor Press
I know an arbor press can squish things, but other than that.. How are the Plates used? Used as dies? Vertical? As you can see I need a mini tutorial on how it works and what you can use it for. I'd like to uniformly bend a bar. ANy help would be appreciated.
Oldwolf
I personally don't have an arbor press, but I have upon occasion used them. They are good for stamping metal, the die is lowered against the metal (a blade in a knifemaker's case) and pressure is applied to the wheel to press the stamp into the metal as firmly as possible. Then a sharp tap on the top to the bar with an appropriate hammer (dead blow is best) transfers more energy to the die sinking it deeper. As usual, practice is needed to get it to perform best.
The press can also be used to lower the electrode used for etching down on the stencil, thus eliminating the shaky hand.
Another use is for pushing bearings onto and off of shafts, or in and out of recesses (this is where the plates come in) They can be used to set snaps, rivets, etc. & reload ammunition (usually a slightly different setup but with the proper adapters for dies it can be made to function.
I have used them to hold parts in place while adhesives cure, cut gaskets and spacers (requires appropriate dies). Most anything that can be crimped by hand can be crimped with a press if proper dies are available.
I realize this doesn't tell you how to use the press, but it hopefully give you the general idea as to what it can be used for.
Go on line and search on arbor presses. Look on the manufactures sites for examples of their products in action.
Jim Arbuckle
ABS JS
You can use it with a jig for stamping blades.It is a good pin press.Its nice for removing pins too for times like voids in mosaic pins show up after glue up and final sanding.:mad:It works great for press fitting bronze bearings.And most importantly t is an awsome nut cracker.;)
Thanks guys, I've been looking at them and wondering. Sounds like a useful tool. Is 1 Ton enough for most work? How are those weird looking plates used?
I have one that nobody at work wanted. My kid likes to munch aluminum cans and bugs (don't worry he cleans them up) with it. I use it for a Kydex.
We used them at work for pressing plastic parts together.
Those weird looking plates are for backing up your work to press shafting or bearings etc. I have a large one (3 ton?) and it is barely heavy enough. I use my hydraulic press much more. I fact since I no longer stamp my blades I use mine as a hat rack. But I would not give it up as it can come in handy for intricate pressing.
