Thanks,
That's the kind of feed back I was hoping for... What do you place inside the foil to remove the oxygen?
Thanks again....
Lee
A better question, how about filling your foil with argon? At double the weight, it should be easy enough to keep in the pouch while you seal it.
Squeeze as much air out as you can. The believe the foil is designed to absorb any remaining oxygen inside the packet.
