- Sep 4, 2005
Sounds like the OP has got more knives than brains . . .
I believe this is the dumbest post I have read this week. Would you trust your car to a mechanic who changes spark plugs with a hammer? Socket, hammer, they're both tools, right? Either one should work, right?
I believe in being prepared, and carrying only a single tool (knife) is not my idea of being prepared. Along the folder I carry a multitool, a prybar/wrench, a flashlight, a lighter, and a USB drive. The multitool has pliers, philips screwdriver, 3 sizes of flat screwdrivers, can opener, cap lifter, and a punchdown tool.
The OP suggested in a pinch, you use your knife for something that it can probably handle although not specifically designed to do.
The hostility is unwarranted as well.
If you want to use your knife as a pry bar or screw driver go ahead. Just don't complain if it breaks. If you want to borrow my knife to use as a pry bar I'll probably won't let you have it. Or I'll get very uptight if you damage it.
I am going to use my hammer to comb my hair and then ill use a screwdriver to butter my bread right after i use my knife to pull up some nails.....see where im going? use the tool for its intended purpose
this post smells like a troll attempt IMO
Without my handy blade, how would I pull fuses out of a fusebox? How would I get the screen off my window?
Every one of you, at some point, has used a knife to pry, scrape, and screw.
