- Sep 4, 2004
Thanks for that info. If the polish you get with the u-fine rods comes close to the level of sharpness you get from stropping, I could see big advantages to this over stropping.smegs said:The edge pro can be adjusted to any angle between it's max and min angles. I don't strop that much anymore since getting the ultra fine rods for the Sharpmaker. I usually like to go at least 3 degrees or more for the secondary bevel.
Seeing the kind of care and precision some are using, I think it's time Spyderco think about a variable angle Sharpmaker.After I'm done with the secondary on the Edge Pro, it's on the the ultra fine Spyderco rods for two or three very light passes on the corners and then one or two at a slightly higher angle. I've gotten great results with this procedure and it seems to produce the most durable edge so far.
That's a shame .... Reeves not responding, I mean. I would think a maker would at least like to see what's going on for himself. Can you post a link to that review or threads describing what happened with the plywood, etc.? I somehow missed that.Cliff Stamp said:It explains to me some of the earlier results such as when it basically exploded on the plywood. As it is now it doesn't get much use. I have emailed Reeve about it with no responce. I might get it rehardened but that is difficult to do with the complex steels if the structure was damaged because they are difficult to normalize.DoW said:I'm still surprised that fracturing would show up now after all the work you've done on that blade.
The Sebenza was interesting because I had been using it on the Sharpmaker for some time and then it just suddenly starting cracking apart and would not sharpen at all. I actually ground off a number of visible chips and there was no sharpening responce to the edge at all. I think what may have happened is that the primary edge grind was too low and the steel was fatigued and thus all that edge is now weakened steel.
I've only heard a little about Zubeng. Sounds like this will be a very interesting review.Cliff Stamp said:Yes, the fine ones alone give a high degree of push cutting. I have to check the Zubeng responce to different hones anyway so I can use it to benchmark the grits. It is near the ideal steel to use for such an evaluation because the carbide size is small and the hardness near optimal.DoW said:I wonder if the u-fine Sharpmaker rods might approach a level of finish and sharpness that rival stropping.
At some point I hope to reprofile at least a couple of Moras to full flat grind, so will add that to the list of things I want to look at. Somewhere I saw a picture of a Roselli UHC blade that was made that way, pretty much full flat grind and obviously very acute, but haven't been able to find one I could buy. If you know a source, let me know.Cliff Stamp said:The steel on those knives has a large influence as well because it is optomized for that type of edge.DoW said:I still have a hard time getting consistent results stropping "regular", meaning non-Scandi, edges.
Well, this is just one of those seat-of-pants things I decided was good practice, not necessarily with much understanding beyond avoiding obvious problems. Freehanding it's easy enough for me to get careless and have the blade contacting only the edge of the stone (one reason I like to carry a rounded slip stone for field sharpening, at least it's not as brutal when that happens) plus I found edge durability is better if your finish sharpening is done with a progressively lighter touch. Finally it occurred to me that the rounded belly, which is the part of a blade I usually use the most, gets a lot more pressure per unit of area than the straight part of the edge if you keep using the same sharpening force.Cliff Stamp said:Generally you want to keep the pressure to a minimum which produces aggressive cutting action because the higher the forces the more likely the edge will bend. After thinking about your comment recently I checked the no-name after regrinding and you can see a massive difference from the x-coarse DMT if you press very hard vs light. At maximal pressure there can be a deformation burr which is visible at about 0.2 mm wide it should have been obvious that this isn't a good idea in terms of trying to obtain a very sharp edge because none of that steel will form clean and the steel above it is likely highly stressed as well. Thanks for pointing that out.DoW said:Even on a benchstone, I keep the pressure moderate.
I've never heard of or thought to look for a deformation burr like that, but that seems reason enough right there. I'm not going to suggest you incorporate that as a regular test when reviewing knives, but in some instances it could be pretty interesting IMO.
