Matthew Gregory
Chief Executive in charge of Entertainment
- Jan 12, 2005
Wow, hardheart... THANK YOU!!!!
More recent research into martensite morphologies have revealed that they are probably the result of the temperature at which they are formed, however this is inextricably tied to the alloy content. Most alloying will lower Ms and carbon is one of those, so the more carbon you have, the lower will be Ms and this will make the martensite more plate like in nature. So this gives the possibility of raising Ms by not putting as much carbon in solution, but allowances would also have to be made for other alloying elements, things like moly have a very profound effect on Ms. But much of this is a mute point to most bladesmiths since the controls necessarry to put precise predetermined ammounts into solution, and no more, is not exactly realistic with a forge All the same if you add this to the hazard of retained austenite, it you get all the more reason not to overheat your steel before the quench.
To put it into common terms:
Dwarfs control the temperature curves of steel.
Elves determine when the Ms and Mf will happen.
Gnomes are responsible for alloying and carbides.
Trolls are responsible for most warpage and bad quenching.
When they all agree you get a perfect HT and a high quality blade.
Since they seldom agree, you usually have a trade off.
When they are really fighting, you get "PING".
There, that should clear it up.
Stacy
I'm sorry, but I have a hard time believing that one...
...It is my understanding (probably wrong) that if you were to do a simple water quench on 1095 (from full soloution) you would end up with a great deal of high stress plate martensite, wheras on the other hand, say, 1050, while barely sufficiently hardenable, would make all lath martensite which is much tougher...
The closest thing to what you're asking for is Vanadis 4, though it has higher wear resistance than 3V, not less, but it's only available in round bar and thick sheet, and only through Europe. 3V has around 5% vanadium carbide by volume, and Vanadis 4 has around 8-9% vanadium carbide.i just puilled some thing from all this
cpm3v is .8 carbon and has 2.75 V in it so is that why the temps are over 2000 for most heat treating
it was my thought that having a "cpm2v" beign something on the order of 1.0 carbon and 2.0 V with the same other as 3v would make for a great steel (fine grain higher wear and higher hardness) as i could then harden it up to 64-65 and temper down a hair like i can with cpm10v. as fine as 1v sounds it to me jsut seems like its too soft being .55 carbon and 1.0 V
mind you im looking for a good high carbon kitchen knife steel (air quench)and love 3v but think i should be able to get it harder
Would 1080 be noticeably more resistant to rolling and plastic deformation than 1055 if both were tempered to the same hardness?
Perhaps I should just take a hint and read some of the wonderful metallurgical texts shared here, but would anyone hazard a reply on my earlier question in the interests of instant gratification?
Quote:
