Or I use a carbide sharpening tool as a scraper.
I use the spine of my knives to strike sparks. Frankly, my knives are tools. If that leaves a mark, which to date it has not, who cares?
The spark is what counts, right?
I looked that up and that Corona Super Carbide Tool is neat. I'm gonna have to get one or two. On goinggear they have a video. Guy said he picked it up for $2.99. but everywhere I see it online it's like $7.00.
I will use the spine of my knife, but I always keep a lucky rock (my nephew gave it to me) which happens to strike Ferro rods. Always with me, too.
The ONLY striker I use is the spine of a knife.
It will not damage your knife or discolor it beyond being able to be rubbed out.
A few things ARE required though, for the spine of your knife to work well.
*The spine must be heat treated
* The knife cannot be a laminated blade
* The spine must be a sharp 90* angle (this can be accomplished with a file)
The only thing that will happen after repeated use, is the "edge" of the spine will lose it's sharpness, just like the knife's edge does when you use it. So, when the spine stops throwing sparks quite as well as it used to, it's time get the file out and square it up again.
I always used a hacksaw blade or the awl on my SAK's, until I tried the spine of my Fallkniven F1. I fully concur with Hollowdweller, I have a laminated VG 10, and it throws more sparks than anything I've ever tried! - except my angle grinder....A few things ARE required though, for the spine of your knife to work well.
I think you make a very good point, and you have very well explained what is required.
But, for the average guy, I think it is too much for him to try to make sure that the knife he buys will have a spine that strikes sparks. And most guys are not in a position to modify their knife, so that it will.
I think a high-quality scraper(striker) is the answer for the vast majority of people.
Now, if you are going to buy a custom knife, and you require that your knife-maker build this feature in, then that is a whole other story. Though, if I was going to build one in, I don't think I would do it using the spine, too much risk, I think. I think I would want to build it into the ricasso area.
Marion
I always used a hacksaw blade or the awl on my SAK's, until I tried the spine of my Fallkniven F1. I fully concur with Hollowdweller, I have a laminated VG 10, and it throws more sparks than anything I've ever tried! - except my angle grinder....![]()
If you knife is able, it will do a fine job as a striker, and it will not be damaged or permanently discolored in any way.
You don't really need to "build" in a striker on a knife. All that is required is that the spine is not left soft, and is heat treated(most knives are except for some customs that are differentially heat treated). If that is the case, all you need to do is use a file to "flatten" the spine so it has sharp 90* angles at the edges. In other words, if the corners are rounded it won't work.
Also, what "risk" do see by using the spine as a striker? I would think a ricasso striker would pose more risk, because now the knife edge is facing the hand that is holding the ferro rod. Regardless, none of my knives have a ricasso area, so I couldn't do it that way if I wanted to.
The striker that came with my fire steel works so much better than any knife that I have tried that it's not worth the effort to use the knife. However I have found also that few tools spark better than the back of the Opinel blade.Instant spark shower.
* The knife cannot be a laminated blade that has soft(un-heattteated steel) on the outside.
