- Apr 14, 2014
Hey all,
I'm working on a Tanto that I'm making using the stock removal method. This build is going to be the most complicated one I've done so far (previous are 3 piece - blade, scales, bolts), but I've tried doing a little forging for the Habaki.
I've taken stripped electrical wires and tried hammering them into a billet that I could make my habaki from. However, all I've ended up with so far is a grey brittle mess! Copper Oxide being the culprit.
At first I was able to make a small billet, and this was fine. But then when I tried to fold it and add more copper it just wouldn't weld and would fall apart. So my question is this:
Is there a flux that I can used with such small wires? If not could I try putting them into a stainless foil envelop (airtight), heat them up and then hit them a bit to get the basic billets and work from there? (Yes I know this would be 'working blind'.)
Of course, casting is an option... but don't know if it's one I'm happy doing in my tiny garden... Should I just abandon such 'recycling' ideas?
Many thanks for your input and time Ladies and Gentlemen!
Mike
Mike
