- Jun 5, 2012
I've been reading up on stabilizing, because I am very interested in setting up to do it myself. Just a quick background, I spent 10 years working at a company that manufactures industrial high vacuum equipment and controls, and several years at an aerospace company, working in composites (resins, vacuum molding, etc.). I also have many years experience working with (and storing, and curing) various local and exotic woods, as I did musical instruments as a hobby before I got into knives instead. I'm also in a terrific area, since I live in the desert I've never had many problems with excessive moisture content in my stock.
I know that people are usually discouraged from DIY stabilization, but I feel I have the professional experience necessary to do this properly once I have time to learn the peculiarities of specific woods I'm working with. Most of my experience is in research and development, specifically design and production of prototypes, and developing repeatable manufacturing processes for them. I can completely understand why it would be most practical for the majority of people to not take this on, and just send stuff out instead. That said, I'd still like to give it a try.
I have read many different things on this subject, with postings and info going back over a decade, but a few things stuck out for me. One thing I've never seen mentioned so far is temperature control. If you were to put a fairly wet piece of wood in a vacuum chamber, it would freeze during pumpdown, due to evaporative cooling. Any time you try to outgas water from something, you have to be very conscious of freeze-up or you will have poor results. The ice will eventually subliminate, but it will take essentially forever compared to a temp controlled process.
This presents a bit of a conundrum, since the resins that I've seen people refer to are generally heat cured, you can't heat to assist in outgassing when doing the traditional DIY submersion method. This may be the reason I've seen mention that the professional places introduce the resin after outgassing the wood. Gentle infrared heating during initial pumpdown of the wood should make for a faster and better quality stabilization process. There are infrared heaters available that are meant specifically for use in this application.
I've also seen mention of use of pressure, but I'm still trying to figure out why. Once the piece is fully de-gassed (well, nothing is really ever fully degassed, but at least within reason), atmospheric pressure and capillary action should really be enough to do the job. I suppose if the wood was extremely fine grained, the viscosity of the resin could have an effect on the rate at which it migrates into the wood, in which case a pressure assist could be of benefit, but I can't really think of any other reason. I suppose if a wood had some type of enclosed inclusions that were resistant to outgassing, very high pressure could help to "crack" them, but I am not incredibly sure on that one.
The results that people are getting with the "Cactus Juice" brand resin look quite good, but I'm not sure whether there is something more "professional" I should be trying to work with. I've seen that there's a few resins that have been used in the past, but opinions on them become more mixed as you go forward in search results.
