Well Spence, it seems that now you are ready for a good sharpening session.
I do mine with bench stones generally, but it also depends the amount of steel to remove.
Basically, if you got big dents, here is what I do:
Mecanical:
Rotative steel cutter, 10000 rpm with variator, equipped with norton rubber-coated sanding plate. Adjust to low speed (heat), use a 220 grit for a start. NEVER sand rotating toward the edge, but AWAY. NEVER position the edge toward you, but AWAY.
Don't try this if you have never practised before, as you'll grind bigger dents, in less time it takes me to tell it. (the rubber padding allows some excess of pressure, and also follows the convex). Maintain the angle between the disc an the blade as low as possible, because if too high, it grinds concaves (a disc edge).
The secret is to never stand on the same place. Use the reflection of light to see what you grind. I generally do this blade in one hand, grinder in the other, and swich for the other face, but you'd prefer a fixed post.
This is extremely fast in removing metal. Extremely dangerous too, if you do not get basic precautions, in clothing, position and movements. One must have seen a bit of steel catching in the rubber and flying to understand that you do not want that with a 14" knife blade.
By hand:
Gently hammer the rollings back flat if possible , take care not to chip edge doing this.
Medium norton india, use in one hand (faster movements) , blade in the other (take care about not cutting yourself), or use as a bench stone (can put pression). If you need to check your grinding angle, use a black permanent marker on 1 cm around the edge, you'll the see what you grind. With time you'll use the same technic, but with the refection of light on the blade only. On a convex edge, I expect to grind on half the blade's width to a maximum of 3cm) to maintain the profile.
After you have cleaned the dents, come back to smaller and finer grits, only on the edge and the near 1 cm. (my stones are then ceramics from spyderco, starting at medium, down to extra-fine, though the extra fine is only used for the final polish touch). But before, it you take care about finish, use a 400 or 600 water sanding paper longitudinaly to remove the traces from the norton india, and restore the look
Do not care while doing this about all recomendations you heard about the direction of the grinding, use the most obvious one (parallel or nearly parallell to the blade), until you have done most of the work (by changing angles), then switch to 45 against the edge (cant do 90 on big blade, not enougth stone length!).
The angles must match the convex edge, so you need to learn them, by either checking the reflection of light in the blade while grinding, or using the black marker tactic.
My field tactic is to forget about the profile and get the sharpness at any cost (angle included).
