I asked a few people and then i talked to a guy i asked about glue so i went ahead and tried to glue my diamond wood handles on and pin them with 3 min epoxy. What a f __ kin night mare . I will not use anything less than 6 min epoxy and ill try to find 20 min but I havent found any . So this is what happened I had the holes drilled all perfect 2 pin and 1 lanyard hole so i had everything ready . I mix the epoxy tapping hammer ready clamp ready i mix the glue spread it on both pieces line drive the pins through the one side and thropugh the steel then tapp the lanyard tube into place then the next pin and that was all she wrote the F__kin epoxy set and i couldnt get the last pin in so the gap would close leaving a 1/64 gap on the last scale . I was mad because i spent alot of time and effort up to that point. I took a sharp chizzle and chizzled off the handle smashing it to pieces to say the least then I was able to remove the other side in good shape but didnt have another piece big enough to work to retry . Will devcon 6 min epoxy give me enough time to do what i need to do pin and clamp. Please let me know im having a tuff time finding 20 min epoxy.I was using 3 min I stirred it for 1 min and worked on it for 1 and 40 seconds and i was toast. kellyw
