The USA hasn't used DC current as a standard since Thomas Edison lost the AC/DC battle against George Westinghouse. By 1900 there were few places using DC. As far as I know the last US holdouts stopped using DC current when I was a young boy in the 60's. Most of the world had stopped by WWII.
The USA transmitted power is all AC - Alternating Current, at 60 cycles per second. A transformer only lowers (or raises) the voltage. A rectifier could change the voltage from AC to DC, but there are no rectifiers in your power system.
The power is generated at the power plant, and sent down the main lines at around 330,000 volts AC ( voltages I am using are one of many combinations). This is reduced by transformers to 33,000 and then 3,300 volts as it goes around town. At the telephone poles on your street, the transformers reduce it to 110/120 volts AC. Usually two phases are sent to your house, thus allowing 240VAC to be used for heavier amperage equipment , and 120VAC for normal things.
Stacy
