Variable-speed conversion for Grizzly 2x72
I got a 3-phase motor free from work and I already have a VFD drive, so I'm drawing up a VS conversion for my Grizzly G1015 grinder. I think I can make it at least as stable as original and solve some of its quirks. Cost looks like about $100 in parts and materials and about that again at the machine shop.
Is anyone else interested in a conversion kit? What about a WIP of the process?
Doc
VFD's (variable frequency drives) are use to adjust the Hz of a moter to get rid of harmonix and for energy managment! i was unaware you could use one to adjust seppd on a grinder? or are u just using it to convert your power to 3phase?
Both. TECO's VFDs are real popular here.
Doc
thanks !! ya learn somthing new every day on blade forums:D as ab electrician im used to installing them on HVAC units!
PLEASE do a WIP... I have a grizzly and am very interested. Awesome!!
Rick
Yes, do a WIP most definitely! I know a guy who pulled his Griz grinder apart and set up both sides (the contact wheel and buffer) on separate shafts each supported by a pair of pillow block bearings. Each side had its own pair of step pulleys. That way he could drive either side independently via the original double shafted motor with belts. He made a couple other mods. Can't wait to see what you do. Sounds like you got some good prices on a motor and VFD!
Don't get rid of the motor, I sold the belt attachment part of my old Griz and still use the motor as a buffer. Long staffs and 1700 RPM, 15 years old and still runs fine.
When a problem comes along - you must WIP it!
Dave
15-yard penalty! Roughing the pun! :D
OK. I've had loads of fun with Sketchup. I should mention that I'm only willing to put a certain amount of time & money into this. After a certain point, I'd be better off just using the wheels & tensioner on a NWG or EERF project. That's why there's a $200 cap.
I. This is the Cadillac version - it requires some machine work and some welding. In case it's not obvious, the vertical arm from the Grizzly slides onto the protruding end of the round tubing. The bearings seat at each end and the shaft goes through the middle.
A) Basic BOM so far:
1. 3" x 5" x 0.25" rectangular tubing, 5.25" long if you're welding this, 6.25" if you're bolting the bore in.
2. 1" x 12" shaft, turned and threaded to taste.
3. 2.5" OD, 1.5" ID DOM tubing 8" long.
4. 2 ball bearings. Bearings may end up being something more like 25mm ID and 47mm OD instead of 1" ID/2" OD. Metric bearings are a LOT easier to find.
B) My Sketchup skills aren't great.
1. The drawings show the bore welded solid to the base, where I'll actually run about a 2-in-5 skip weld.
2. You could avoid welding at all if you drill & tap the DOM tube across the center at 1-11/16 (1.6875") and 4-3/16 (4.1875") from the pulley end, or the left if you're looking at Grinder2_3. Make the saddle in the rectangular tubing at the same height, raise the sides to 6-1/4" and bolt the bore in. I figure 3/8 fine thread should be plenty.
3. I snatched the bearing drawings as 3D Models off the web, so their OD, ID, and width are not to scale. Sue me. ;)
C) It's also not all there:
1. I haven't decided whether to use 2 x 2 x 3/16 angle iron front & back to bolt the 3 x 5 tubing to the table or weld it to a flat plate.
2. It needs a mount point for a work rest. I'll probably just bolt the original work rest to the 3 x 5 for starters, but eventually I'd like to add a mount point for a MAP Arm style rest.
3. Obviously, I didn't get around to looking for a pulley. It goes on the unthreaded end.
II. The Honda Civic version. Minimal machining and no welding. No drawing yet.
A) Make the rectangular tube 8" long, bolt a flange mount bearing on one narrow side and part 33C (See photo) from the grinder on the other.
B) Bore the end of 33C for your bearing and done. The same shaft and bearing dimensions as the Caddy version should work, with maybe some adjustment to length.
C) The stock workrest should bolt right up.
What do you guys think?
Doc
