Patrick Vallee
- Jun 30, 2021
Good Morning BF,
I have several fixed blades for you this morning. I take ppff only, and will ship within 24 hours. If you want more than one, I can do better deals. If you want all of them, I will throw in the green ZAKY knife for free!
Pawel Surdel Hatchet/Tamahawk - A new condition forged camp axe from Pawel Surdel (Papstomahawk). I am the second owner. Handle is hickory. OAL 19 1/2". Toe to Heel 3 1/2". Blade edge to Butt 6". Very well balanced with a nice polish - 1.5 LBS. Not sure what Pawel used for steel on this one but my good guess is 1055. Pawel made the leather blade cover (sheath) as well. Asking ... 225.00
ZAKY (red) - Kydex Sheath has a leather dangler provided by one of our own here on BF. This one is new/never used ... SOLD - THANK YOU!!!
Steel: 80crv2 - 60 HRC
Thickness: 1/4" (6.3 mm)
Length: 12.5" (31.7 cm)
Blade length: 6.7" (17 cm)
Handle: Red jute micarta with black paper micarta spacer, black liners and copper pins
Boltaron sheath compatible with TekLok attachments
Zaky (green) - Kydex Sheath has a leather dangler provided by one of our own here on BF. This one has been lightly used ... Asking 100.00
Steel: 80crv2 - 60HRC
Length: 9.2" (23.3 cm)
Blade length: 4.25" (10.8 cm)
Hollow grind
Handle: Green linen micarta, black liners, stainles steel pins.
I also have a special one from Knife Modders. It is the Revnant in CTS XHP, hollow grind, polished richlite scales with kydex sheath and soft loop. If You Follow Richie and Lyndy you know that this is the one that was supposed to go to Blade Show 2023 ... Lightly used Asking 200.00
As always, Thank you and Blessings!!
Hollow grind
OAL: 6.4"
Cutting edge: 3"
Blade stock: .135
Flat saber grind
Svord Von Tempsky Forest Bowie - This one is new/never used ... Asking 200.00Specifications
- Blade Length: 11"
- Overall Length: 16.5"
- Blade Thickness: 5 mm to 7.5 mm (exact specs may vary)
- Steel Material: Swedish l-6
- Full Tang Construction
- Leather Sheath with Vertical-Carry Belt Loop
- Weight without Sheath: 27.3 oz. (774 grams)
- RC Hardness: 58
- Weight with Sheath: 34.6 oz. (982 grams)
- Leather Sheath Included
