Who was it that recomended a mixture of 50% parafin, and 50% vaseline? They said if you melt equal amounts of each into a small container, that it makes for an excelent lubricant that doesn't wipe off too easily yet doesn't attract dirt/grime. Anyone here ever try it?
That was me...
I've used 50:50 vaseline:beeswax for 30+ years on various low-speed, high-pressure joints,
like knife pivots, gate hinges, pliers, wire cutters, bicycle chains, etc.
Beeswax is a 'sticky' wax but, for low-speed applications, it works great because it has
excellent film strength, that is, it stays in the joint and prevents metal-to-metal contact.
It also adheres like crazy to most surfaces (like steel, brass, etc) so it won't easily wipe off nor sling off.
The problem with it is that it's hard to get into tight joints, like knife pivots, and, used in pure form is too 'thick' ( or viscous).
To solve that, you mix it with another, lighter oil or wax, like vaseline, or (my favorite) automotive refridgeration oil.
But, almost any lube oil will work to 'thin' the beeswax. I've used 30wt motor oil, etc.
Mineral oil won't work, nor will silicone grease, because beeswax will not dissolve in them...they're chemically too different from the beeswax.
You can adjust the viscosity of your homemade grease by adjusting the beeswax content. A 50:50 mix of Beeswax:vaseline gives a grease about like shoe polish. The same ratio with auto oils is thinner. While you're at it, I'd make two versions, say, 50% beeswax, and another batch of 25% beeswax.
That way you have both a thinner and a heavier grease.
To get it into tight places, apply a small dollop to the edge of the jount, then heat the object with a hair-drier, heat-gun, etc, just to the point where the grease melts and flows into the joint. Allow to cool, then wipe off the excess.
Another way to apply it is to add quite a bit of lighter fluid to your 'dollop' and paint, drizzle, or inject that into the joint. Lighter fluid dissolves both the beeswax and the vaseline, oil, etc and allows it to flow properly. Then, thru the magic of evaporation, the lighter fluid will evap, leaving your lube in place in the joint. I use that method for knives I don't want to heat up with the hair drier.
Works for me.
