- Sep 20, 2014
Check out the Velos for an excellent and inexpessive choice for EDC. Wear it on your gear or use it as a neck knife - it's sure to be up for any challenges with a tough stainless tang forged from CPM 20CV. Enjoy!
Take a closer look here: http://btacblades.com/collections/spartan-blades
Velos (Vee-Los) - a fitting name for this small lapel dagger-tool, Velos, is Greek for arrow or arrowhead. Our inspiration for this design was the OSS lapel daggers made famous in WWII. This everyday carry (EDC) knife-tool can be worn around the neck or in a pocket. The Velos design makes it a comfortable everyday carry fixed blade with great ergonomics. Velos is perfectly suited for back-up and survival, as it is small enough to hide almost anywhere! The form fitted Kydex sheath comes with a stainless steel neck chain. Made of CPM 20CV, the knife holds an edge while resisting corrosion very well with 20% chromium and 1% vanadium.Handle has a flat-tip screwdriver and hex tool cut out that can be used when sheathed (sheath is handle).
Specifications:
Knife Name: Velos
Designer(s): Iovito
Overall Length: 4 7/16"
Blade Length: 2 1/8"
Blade Thickness: 3/16"
Blade Steel: CPM 20CV
Blade Hardness: 59-60 HRC
Blade Style: Dagger with hex tool and standard flat-tip on handle.
Coating: SpartaCoat - PVD - Tungsten DLC (Black or Blasted)
Sheath: Kydex (Black).
Weight: 0.063 LBS (Oz) (Knife)
Specifications:
Knife Name: Velos
Designer(s): Iovito
