- Dec 15, 2021
Good morning. I am sitting here frustrated and looking to see if anyone else has the same issue or a solution.
I recently upgraded my pocket knife sharpening setup to a TSProf Blitz 360 along with a set of Venev Centaur double sided stones from Gritomatic. The sharpener is fantastic quality and at first glance so are the Venev Diamond stones. However, my set of Venev stones is not consistent with one another. They are all different thicknesses which makes it impossible to keep a consistent sharpening angle when changing between stones.
I purchased three stones, a 100/240, a 400/800, and a 1200/1500. The first two, 100/240 and 400/800 are almost identical with one end of the 400/800 being slightly thicker than the other. This is barely noticeable when setting the coarser two down side by side on a flat and level surface. The slight variation causes the angle to change when swapping stones but not realistically any more than when a stone isn’t completely seated in the stone holder. The greater issue is with the 1200/1500 stone. It is visibly thicker at one end and is thicker that either of the other two stones. There is no way to keep a consistent angle when changing to this stone. Is this the same experience had by most Venev diamond stone buyers? Do the Edge Pro matrix stones have this issue? Do the Venev Orion stones have this issue?
I realistically want a set of stones that at least all start out the same thickness “at least I think I do because it seems like the only way to get a consistent and near perfect bevel. I know that over time, stones will wear at different rates but with modern diamond matrix stones I don’t believe this is something I should be having to deal with, at least when they are brand new.
I’m looking for advice, should I fix or return this set? Is there a better option? Am I looking for perfection when I should instead be using an angle finder every single time I change stones and be happy with my Venev stones?
Thanks in advance for the help!
