Verhoeven Experiments on Knife Sharpening--Wow!
Hey guys,
In that report... he talks about diamond spray compound for his strop. Does anyone know where to get that stuff and also what grit he was using cause apparently their avaliable in many many sizes, from 600 to 200 000.
Graves, Amlap or most lapidary supply companies have diamond spray as it is used for gem faceting. Your 0.1 micron stuff will be about 200,000 mesh.
so when we talk about the green veritas stick of compound.. thats 0.5 microns right?
Verhoeven was using the 200 000 mesh (0.1micron) spray?
does "mesh" correspond directly to "grit"?
Not an exact correlation. The diamond folks have the higher grits as follows:
1 micron = 14,000
0.5 micron = 50,000
0.25 = 100,000
Yuhuza just mentioned 0.1 micron = 200,000. If you go back to aluminum oxide, there's a powder called Linde B which is 0.05 microns :eek: It's slightly softer than Linde A (0.3 microns), but harder than most steels. Still, to polish out the larger scratches left from the stone or compound used before you move to Linde B would probably take weeks.
No, mesh corresponds to a theoretical sieve number once you get to particle sizes too small to construct an actual sieve. A 10 mesh sieve would be a screen having 10 holes per linear inch or 100 holes per square inch. Allowing for the wire diameter, a 100 mesh sieve will drop particles with a diameter less than .0059 inches or, if you converti it to metric, 150 microns. After a certain point (about 300 mesh) the wire size becomes problematic and the wire starts taking up more space than the holes and it becomes impractical to build finer screens. 200,000 mesh would be a seive with a screen having 200,000 holes per linear inch. Virtually impossible to build even if you could find wire fine enough to make such a screen. Here's a mesh to micron chart http://www.showmegold.org/news/Mesh.htm For really tiny particles, they find the size by some other means (there are dozens of methods) and then calculate an equivalent mesh size.
Grit is a number assigned by any one of a dozen different industrial standards committies (ISO, ANSI, CAMI, JIS, FEPA, DIN etc.) Each one gives a formula based on particle size, volume, packing density or some such, as well as a statistical error range, (sometimes adjusted for the difficulty of measuring finer particles so as to allow more slop on that end or to compensate for needle shaped grains when your grit size is based on the diameter of round particles). For normal distributions see http://bmj.bmjjournals.com/collections/statsbk/2.shtml
Generally, a grit number designates a mean particle size and each standard allows variations within a standard deviation from that mean (sometimes, plus a slop factor).
If I remember correctly, sandpaper goes by the Cami standard and has the biggest error margins. Everyone was asking about Japanese waterstones a year or two ago so I spent a couple of months digging around trying to find the Japanese Industrial Standard grit formulas (found them but wasn't going to pay $60 for a pdf of a standards paper in a language I can't read), but I did manage to find a chart on the web site of a Japanese abrasives manufacturer and created a web page out of it http://members.cox.net/~yuzuha/jisgrits.html (this table is based on a more recent 1998? standard that specifies measuring particle size by an electrical resistance method... the older standard was based on flotation and allowed slightly larger particles than the current grit numbers)
column one is the JIS grit number, the second is the mean particle diameter, the third specifies the range, the third is the absolute maximum (if a single particle is found that is larger than this, the entire batch must be resorted) and the last two columns give the 3% error limits.
So, if you order a ton of JIS 1000 grit aluminum oxide abrasive and plot the particle sizes on a gaussian bell curve, the mean would be 11.5 microns, with an error of 1 micron so the majority of the particles fall between 10.5 and 12.5 microns (some standards say 50% of the particles must fall in this range, others specify those numbers as the 1 standard deviation from the mean point so 68% would be in that size range). No particle in a batch of 1000 grit abrasive can be bigger than 32 microns (if one is, you can reject the batch as defective). The last two columns in the chart show the 3% limits, so 97% of the particles have to be larger than 7 microns and 97% have to be smaller than 27 microns (if more than 3% are between 27 microns and the max of 32 microns, you can again reject the batch as defective and send it back to the factory)
Basically, the numbers in this chart can be used to draw a bell shaped curve of particle sizes for each grit number and Japanese manufacturers have to grade their abrasives so they fall inside those limits if they want to do business in Japan. Of course, there is nothing stopping manufacturers from trying to get a better reputation by exceeding the standards, or selling premium abrasives (the bell curve would then have the same mean of 11.5 for 1000 grit, but be higher and narrower so a much bigger percentage of the particles will fall in the 10.5 to 12.5 range with much fewer than 3% falling in the abnormally large or small range)
Some grit numbers accidentally happen to be similar to mesh numbers so people often call the mesh numbers grit, but they are different. i.e. 3 micron diamond dust ranges from 2-4 microns and is 8,000 mesh, while 8000 grit JIS is 1.2 microns ranging from 0.9-1.5 microns
For diamond dust in microns
average / range / mesh number
0.1 / 0-0.2 / 240,000
0.25 / 0-0.5 / 100,000
0.5 / 0-1 / 60,000
1 / 0-2 / 14,000
2 / 1-3 / 11,000 (equivalent to a 6,000 grit JIS waterstone)
3 / 2-4 / 8,000
6 / 4-8 / 3,000
9 / 8-12 / 1,800
15 / 12-22 / 1,200
30 / 22-36 / 600 (about 400 grit JIS)
45 / 36-54 / 325
60 / 54-80 / 230 or 235
Here is another useful table comparing sandpaper, European FEPA p- grits and micron sizes http://users.ameritech.net/knives/grits.htm
Now, you know more than you ever wanted to know and are still confused? So is everybody else ^-^ That is why I just like to go by micron numbers instead of grits or mesh (but even that doesn't help with stones, since the finish a stone leaves on metal depends on the bonding material, grit size, porosity, bond flexibility, bond strength, abrasive friability and the way it fractures... take Arkansas stones for example... they are made from the glass skeletons of sea creatures called diatoms that have been cemented together with more glass / silica, and they have an average diameter of 5 microns. A soft Arkansas is just more porous and loosely bonded while your surgical Arkansas is very non-porous and tightly bonded. One is considered coarse and the other fine, but the abrasive diatom shells are the same size)
Thanks Yuzuha, thats exactly what I needed to know.
Ive found a source of diamond polish here in Australia so Ill give that stuff a go on a new strop I just put together.
I reckon the 100 000 mesh (0.25micron) stuff would work a treat after a fine honing :)
Haven't gotten to read the whole thing yet, but it does seem very interesting.
Cliff Stamp said:
I have seen arguements that for coarse edges the side scratches are a significant factor in the aggression, it isn't just the very edge itself.
-Cliff
Though I have not done any recent testing on this subject, I have long held this belief. Could be wrong, but I've always thought the side scratches help. This is why I will often polish an edge all the way down, and then come back with a coarser stone at a slightly lesser angle and add some scratches back to the sides without touching the very edge itself. (leaving the transistion between edge bevel and primary grind polished for less drag)
The coarse edge left on my bowie by the 120 grit (or so) stone would probably look awfull under high magnification. Yet it cuts better for my purposes than a more polished edge, and is much easier to maintain.
I can't see them hurting, but try this as a simple experiment. Take the knife and do a simple cut into the sharpening stone at 90 degrees removing just the very edge and see how much cutting ability is left.
-Cliff
I've been doing some research on sharpening lately and thought this thread and the linked sharpening paper by John Verhoeven would be beneficial to the new members who couldn't find/didn't know it existed. The pdf of the paper is still printable I think, but I could not save it, as it is protected now.
The .pdf can be found from other sources. I just Googled 'Verhoeven sharpening', and found it within the first few search results (downloaded & saved it, too ;)).
You're welcome then. Seriously, I'm going to try that now so I can find one to download.
Ok, I give. Where did you find it that you could download and save it?
