Cliff Stamp
BANNED
- Oct 5, 1998
Matt :
[CrO / AO buffing compound]
Spyderco is leaving their CPM-440V at about 55RC which is fairly soft, combine that with a very wear resistant structure and you have the ideal recipe for inducing a large burr formation and thus preventing a high level of fine push cutting ability. It is absolutely critical to go as light as you can on the hones and switch sides as often as possible, every stroke if you do it. The hones should be as clean as possible as well. If the edge gets really dull, I would reset it on a diamond stone before using the Sharpmaker as well, proceed to the finest diamond stone you have and just use the Sharpmaker to clean up the edge.
In regards to the CrO / AO buffing compound, no it will not cut the carbides in the 440V (S60V), however it will readily cut the steel matrix that surround them and this is what forms the edge anyway. It can be used to put the final polish on a high alloy steel, but if used excessively it will just induce a blunting action as it can't cut the carbides. Note for the same reason if there is a large burr on a high alloy steel, the buffing compound is not effective in removing it. However there are SiC lapping compounds that are very fine (5 micron) that will do this readily. You would then switch to the CrO / AO compound for the final polish.
-Cliff
Does this mean I might have trouble stropping my Spyderco Military in CPM 440V? I was hoping that this honing stuff might finally let me get a polished edge on it. I can get a sharp, aggressive edge, but I cant seem to get a fine "hair poppin" edge. I've found after I've used the flats of the white sharpmaker sticks, it's best to go back to the corners of the coarser ones to "scratch up" the edge since I cant get a polished edge.
-Cliff
