Gary W. Graley
“Imagination is more important than knowledge"
- Mar 2, 1999
Hi folks, I ended up having a couple of these made up recently, these should fit the Bradford USA Guardian 3 Leather sheath so you can turn that horizontal sheath into a vertical sheath by installing this vertical adapter I came up with, now both of theses do not have any fancy embossing, just my G2, the month/year and also a Right foot print on the back just above the snap fitting.
The 'rules'
Have at least 5 positive feedbacks and no negative ones
and of course, you'll need to have a sheath this will fit on, otherwise, won't do you much good.
How to install it:
insert the adapter, start from the bottom and slide the top snap under the belt loop, it may be a very snug fit to start, I also recommend using a metal ruler to aid in pushing the snap end under the belt loop.
Then pull it through, the smaller bottom bend will hook on to the bottom of the belt loop and then just snap into place.
And, that's about it, I have TWO of these, so the first TWO people that meet the criteria above AND post in this thread are the 'winners'
Simple eh?
Thanks folks,
G2
The 'rules'
How to install it:
Simple eh?
Thanks folks,
G2
