Gotta love physics. But from a distance. I can barely tell which way is up.Some types of locks are prone to up/down blade play. Back locks and axis locks come to mind. It’s the nature of the beast due to the geometry of the lock up and the locking forces at play.
Yep, none of my SHFs have any play when locked, perhaps a minute amount of side to side, but that's just because I run the pivot a little loose.I believe that vertical is in the same axis with deployment; horizontal acts perpedicular to the pivot axis. The lamia is a frame lock. I find it hard to believe that anyone owning a SHF, a CRK, ect. would put up with any slop what-so-eva...
Beat me to it.Vertical is up/down. Side to side would be horizontal. The exact definition of those terms.
Nope. Can’t stand it. Only blades I have with any play whatsoever are OTFs. Nature of the beast on those. Anything else I adjust it out or off it goes.New to the forum hereWhat's everyone opinion on vertical blade play on high end knives? Should this be an absolute no-no or would you be okay with it? For instance my SPK Lamia has some slight play. It doesn't bother me too much though.
How do you go about adjusting it? Just take it apart and apply some inward pressure on the lock bar?Nope. Can’t stand it. Only blades I have with any play whatsoever are OTFs. Nature of the beast on those. Anything else I adjust it out or off it goes.
How long have you had the knife? If you just got it, exchange it where you bought it from.How do you go about adjusting it? Just take it apart and apply some inward pressure on the lock bar?
Is there a consensus on which way is horizontal and which way is vertical on a knife?
I always have trouble discerning…
Can we clear up what kind of blade play you have first? Horizontal (left/right) or vertical (up/down)?How do you go about adjusting it? Just take it apart and apply some inward pressure on the lock bar?
