safe is better than sorry for sure , but over kill is over kill to..
keeping the oil from going over a curtain temperature for the next quench is just as important imho
if you can get past the curve in the time needed and repeat that at the same temperature
for the next quench it's the way I'd want it.
if you over heat a lot of oil it also takes longer to cool a lot of oil.
I'll put it this way
if I quench one blade in 2 gals (more than enough for most blades) of oil at say 165 deg's
the quench will raze the temperature, no problem, it's done it's job for the one blade.
to repeat the quench results I'd want the oil to cool back to 165 deg's. that takes time.
of course the size of the steel and thermal transfer will determine the heat needed to be removed.
BUT...say I have 3 blades to quench
if I have 3 vessels that holds 2 gals and each are at 165 degs I can quench all of them at will.
if you have a way to cool the oil to 165 as fast as you can raze it up to 165
then that would be good but most of us don't have coolers built in.
. I know it's knit picking but if you want equal results you have to have
equal situations..of course you can just WAIT and WAIT and WAIT
for the oil to cool back down on it's own.
if you heat treat one at a time never mind
